HP Pavilion F1503 15 in. Flat Panel LCD Monitor
Problem for HP Pavilion F1503 15 in. Flat Panel LCD Monitor
Help me
By wagnerjason7 on Nov 05, 2009
i have a hp pavilion monitor and the colr is messed up can you help. i need to know what the settings are for this monitor
Solution #1
posted on Nov 05, 2009
Not Rated)
Ricklincs
Rank: Wiz  Computer Hardware  Expert
Rating: 82%, 40 votes
I would try to reset to factory settings first see if that does the trick these are specific instructions for a pavilion vf52 lcd, i imagine they are the same across the board....try it and see how you get on
Adjusting the Factory Recall To recall factory settings back you should follow the steps below: 1 Bring-up the OSD “Main Menu”. 2 Use the ‘+’ or ‘—’ button to move (forward or backward) to the factory recall icon and highlight it. 3 Press the ‘Select’ button to activate the factory recall action.
hope this helps, let me know if i can be of further help
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion F1503 15 in. Flat
Questions and Unsolved Problems for HP Pavilion F1503 15 in. Flat
Do you recommend HP Pavilion F1503 15 in. Flat Panel LCD Monitor?
Answer
Answer
the menu screen appears witout me pushing the buttons, and when i try to exit the menu screen, it... (More)
Answer
my sound doesn't work when i plug in my speakers or earphones, but on the monitor it says everything... (More)
Answer
OSD Main Menu will not go away. two boxes open and the monitor menu buttons do nothing. I have an HP... (More)
Answer
the screen is dim,i hit auto config the screen is normal brightness, then it goes dim again hp... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Pavilion F1503 15 in. Flat...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
