Question about Vizio P2 42 in. HD-Ready Plasma Television
RCA plug stick in back of TV
I have the tip of a RCA plug stuck in the back of my Vizio P2 42 in TV. The tip is inside the female end and I cannot seem to find any tool that can extract it. Does anyone have any solutions?
You might try using an easy out. If you don't have one they are availble at most hardware stores.
Posted on Jan 27, 2008
How to connect headphones
  1. This TV doesn't have a standard 1/8" stereo jack, so you must use the RCA connectors on the back of the TV.
  2. Purchase a 2xRCA Male / 1x3.5mm Stereo Female Y-cable, such as the one available here.
  3. You will also need a set of headphones, preferably a powered set.
Jan 20, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
I have Radioshack wireless headphones with a 30 foot range. I cannot hook them up to my new Panasonic Viera 42 inch HD T.V. - The "audio outlet" is a square and the headphones only have red and...
hi there.
At present, the square connector is what is called an "Optical" connector.  It's purely digital and transmits digital data via what looks to us like a RED LIGHT.  Your headphones are incompatible. Your heaphones have an analog connection on RCA Phono type connections.  The type you usually get on the back of hifi equipment.
The pannasonics DO have a headphone socket, but it is the small 3.5mm type socket.  a small round hole that looks slightly larger than a pin head.  It normally has a small diagram of a pair of headphones above or below the socket to indicate what it is.
In order to connect your headphones to your set you will need a stereo,male 3.5mm jack to two RCA Phono jacks.
If your current lead on your headphones has "male" ends, the red and white ends should have silver or gold points sticking out.
If your current lead on your headphones has "female" ends, the red and white ends should have silver or gold surrounds with holes in.
With this in mind, if you have male ends you will require a stereo 3.5mm jack to stereo female Rca Phono vice versa so that they basically lock into eachother forming a "Constant chain".
I have tried to explain this as best I can, I hope you've managed to get the idea of what I'm saying.
You will either need this :
http://cgi.ebay.co.uk/1-2m-3-5mm-Stereo-Jack-2-X-RCA-Phono-Plugs-MP3-/270689011629?pt=UK_Computing_CablesConnectors_RL&hash=item3f065287ad
or this :
http://cgi.ebay.co.uk/3-5MM-STEREO-JACK-MALE-2X-RCA-PHONO-FEMALE-ADAPTER-/360300626060?pt=UK_Computing_CablesConnectors_RL&hash=item53e397408c
Sometimes the colours of connectors vary.  Just remember that Red to Red (for right hand side)  and White to White or Black To White  or Black To Black (for left)
Jan 07, 2011 | Audio Players & Recorders
I am connecting my dazzle to my pc and to the back of the x box but i try to use windows movie maker to record footage but i cant seem to find the dazzle capture card anywhere on the pc even though i have...
Welcome to Fixya,
What is the model of your dazzle device? Is taht DVC 100? if ever please check this procedure.
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task. step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
Step 7: The tricky part no one ever mentions: On the XBox 360 video cable, there is a switch that switches from HDTV to TV. You must switch this to TV!
Aug 12, 2010 | Pinnacle Dazzle DVD Recorder
No Picture
Hi And Welcome to Fixyah,
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
May 14, 2010 | Pinnacle Dazzle DVD Recorder
No video from dazzle to pc
Hi and welcome to Fixyah,
I have something that can help you with, please checked if this is the same settings.
If you follow any of the videos, it won’t work!
Let me know what happen.
Apr 09, 2010 | Pinnacle Dazzle DVD Recorder
How do i connect dazzle to tv to record ps3 gameplay
Welcome to Fixyah.
Step 4: Plug the Yellow, Red and White RCA connectors from the PS3 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Regards,
Mar 20, 2010 | Pinnacle Dazzle DVD Recorder
Broken Female audio plug
take a 1-1/2" safety pin, straighten it a bit, heat the tip, stick it inside the broken pin, let it cool then work it out w/the broken pin attached. I had the same problem & this worked.
Nov 05, 2008 | Onkyo Audio Players & Recorders
Vizio P2 42 in. HD-Ready Plasma Television Logo
164 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
