freezer side has a drip insede on back panel that comes out on bottom then freezes in the bottom into a block of ice that makes the bottom basket impossible to get out
if you can find the a hole the opening is size of a hose, that is where that water should go, see if there is any small object blocking the way out or the hose maybe clogged, just clean it with hot water, turn it off first
Was this helpful?
Yes
No
Popular Solutions for Kenmore 55612 / 55614 / 5561 /
hi, my LG GWL227HBQ ice maker fridge has been installed today. the problem i have now is - its...
(More)
hi, my LG GWL227HBQ ice maker fridge has been installed today. the problem i have now is - its despensing water at a slow rate. could someone pls help?
Kenmore Elite Coldspot 106.56709500. Could replace the water filter cause the ice maker to quit...
(More)
Kenmore Elite Coldspot 106.56709500. Could replace the water filter cause the ice maker to quit working
My washer filled up with water but when I shut it, the washer will not start. It seems like the...
(More)
My washer filled up with water but when I shut it, the washer will not start. It seems like the switch is not working.
