Question about Whirlpool Duet GHW9150P Front Load Washer
Which compartment is for the laundary soap
I am renting a Whirlpool duet ghw9150 while my other washer is being fixed. I can't figure out the 3 compartments. There is a long one on the right hand side and then two smaller compartments on the left side.I have no owners manual and the place where I rented the machine is not of any help. So my question is what compartment is which?
  • 283 Answers
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Posted on Jan 05, 2008
  • mcmoon2625 Jul 25, 2011
    I am still puzzled. What position do I use if I am using powdered detergent?
Whirlpool duet front load washer with F 06 error message
could be control board, in the past this has been an expensive error code to diagnose
Oct 29, 2013 | Whirlpool GHW9150 Duet Washer
GHW9150 error FH
1) Not water entering to the machine or presurre switch trip not detected. proceed with the instruction manual go to the section troubleshooting and fix it.
2) RUN the test mode diagnostic.
3) if you do not have isntructions manual download for free or www.
God bless you
Jun 19, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer banging Loudly during spin cycle as if off balance
More than likely the washer tub bearing is worn out, this happens due to seal failure and soapy water getting into the bearing, the soap is very corrosive and the bearing fails quickly, this in turn destroys the drum vibration dampers and makes it much worse. The cost to repair this is about $400
Feb 13, 2012 | Whirlpool GHW9150 Duet Washer
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer has error code f dl. there is a buzzing sound and the washer won't drain nor spin.
Hi there
I hope this helps you.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Ty for writing to fix ya.
Best regards Richard
Dec 08, 2009 | Whirlpool GHW9150 Duet Washer
Whirlpool duet washe always out of balance
remove lower front panel and you should see shocks on lh/rh of tub. probably one broken ,replace both. Hope this helps, please rate my solution :)
Jun 25, 2009 | Whirlpool GHW9150 Duet Washer
Light is on that says control lock
Press and hold the "End of Cycle" button for 3 seconds. This should unlock the washer controls. If this does not correct the problem, please post back and let me know, so I can assist you with troubleshooting the problem further.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
531 people viewed this question
Dan Webster
Dan Webster
Sal De
