Usually on the door of the cd drive there is a very tiny hole. If you turn the laptop off. Then push a needle or thin bar in to the round slot The draw should release.
1. Draw the string on the bow
2. While the bow is drawn, use your finger/thumb to hold the cam in place, so it doesn't move when you let go of the string
3. Let go of the string
4. There are three slots on the cam that you can move the string into, with the V of the slots facing up, the slot on the left is 16 lb, the middle slot is 19.5 lb, the slot on the right is 22 lb. Manually move the string to the slot you want.
5. Grab the string again, in the draw position, so you can let your finger off from holding the cam
6. Repeat the process for other other end of the bow, the other cam
The motor is shot,Or the gears are jamming up in it, Just look for a different one, It will cost you more to have it repaired, I have got good used disc (Players) For $10 to $40 at the most for friends of mine,
sounds like you have a bad controller. You should have a primary ide controller that is noramaly used by the hard drive, then a secondary used by the optical drive. Try putting the DVD drive on the some ide cable as the hard drive.
If you're really brave, unplug the unit and remove the case screws. Pop
off the case and get your CD back. The you might need a draw belt. See
prbline.com or studiosoundelectronics.com
