Question about Cobra 29 LTD CB Radio
How do you replace the meter light in a cobra 25?
How do you replace the light in the meter on a cobra 25 mobile CB
You need to open the unit up ( remove the case/cover). Then remove the 4 screws holding the face plate on. Remove all the knobs ( they slip off) . remove any screws holding the meter on ( there may be none depending on which model you have ) . slide the meter out of the face plate and replace the meter with a new meter. Note: The meter light needs to be reistalled in the new meter. It simply slides out the side of the old meter and slide back in the new meter. Replace all the screws, and the jobs completed.
Good Luck and a good weekend to you.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
How do I turn up the the dead key power on a crobra 25 ltd cb radio
There is no adjustment to turn up the carrier power in a Cobra 25 LTD. The AM Cobra's are not like the Galaxy's in that respect. All you can do is tune the output section for maximum on a meter.
Jun 21, 2014 | Radio Communications
Can you expand the freq. range of the cobra 25 CB 40 channel radio
Yes its possible to do with the EXPO kits.. or an eeprom. but beware of the FCC rules please. RX purposes' only not to be used for Transmiting..
May 05, 2013 | Cobra 25 LTD 40-Channel CB Radio
Cobra 25 uk ltd when mic keys needle spikes
It is important to ground the antenna well,get an swr meter and check the swr it needs to be less than 1.5
Jun 13, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
I wish to tune and peak a cobra 25 ltd wx. please tell me what pots to turn. I have all of the necessary meters.
do you have a spectrum analyzer? A function generator , bird 43 watt meter,multimeter etc. ? If you have all these then go to www.cbtricks.com and get the information you need .
Sep 06, 2010 | Cobra 25 WX-NW-ST 40-Channels Base CB...
Cobra 29 NW LTD Classic wont calibrate and red antenna light keeps coming on
The calibrate knob only calibrates the radios SWR meter, the owners manual will show you the procedure for that. If your ANT light is coming on, it is telling you that your SWR is to high, and may cause damage to the radio from reflected power. You should purchase an in line meter as the radios internal meter may be somewhat unreliable. You need to tune the antenna to the lowest SWR possible. Typically anything under 2.0:1 is acceptable. Radio Shack sells a meter for about $50, and is pretty accurate. Antenna mounting can also cause high reflection if it is to close to other objects. Google "CB antenna tuning" or read the instruction manual for you antenna, and you should be able to figure out how to properly tune the antenna.
Jul 07, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
Cobra 18 wx st rf/s-meter does not function
to be sure that u dont burn yr radio try to check yr swr with an external meter to be mounted between the radio and the antenna and check if it works! good luck.
rgds stefano
Dec 25, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Older Cobra 25 ltd
did the gauge stop working or the radio. the gauges on older radios fail quite often . you can order replacements
Aug 11, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
863 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
