Question about Simplicity Serge Pro SW432 Mechanical Sewing Machine
Needle help i can not get my simplicity sewing machine needle to move
  • jlogan Mar 16, 2008
    need to change needle cannot get needle to move. have loosened screws. needle will not move out
  • 323 Answers
Using a pair of needle nose pliers grasp the needle as far up as you can and pull down. Sometimes a slight twist will help.
sewman7
Posted on Jul 01, 2008
My simplicity fashion pro sewing machine is not picking up bottom stitches. It won't sew at all, please help.
Install a brand new needle. If that doesn't help, most likely the machine has been knocked out of time--the needle and hook do not sync. Search for sewing machine timing or take it for service.
Dec 14, 2017 | Simplicity Sewing Machines
Simplicity blind hemmer broke needle, replaced needle and now it strikes the arm instead of floating above to pierce the fabric. Timing issue?? how to adjust?
Yep, most likely the timing is off. (First, check that the needle is installed correctly.)
Search for:
Oct 22, 2017 | Simplicity Sewing Machines
How can I fix my simplicity quilters classic sewing machine that the to thread seems to get hung up in the bobbin case and the machine freezes up and will not sew?
Is it really threaded correctly? Is the needle, old, blunt,or slightly bent? Are the thread and needle compatible with the material? :)
Jul 08, 2014 | Simplicity Quilter's Classic SW240...
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
What size needle do I purchase for my simplicity Pioneer ll sewing machine
contact one of these sites and ask them, I checked on the internet
and couldn't find anything about the machines needles, if it was me, I would try schmetz universal needles,that what I use in all my sewing machines, for cotton or flannel, but if I sew like stretch I would use
ball point, it depends on what fabric is being sewed what needles you
use,, but call or email these sites and ask them what they suggest
sewvacdoctor.com
a1sewingmachines.com
Dec 11, 2012 | Simplicity Pioneer II SA200 Mechanical...
Simplicity model 1512. - quite sewing- the motor will run but needle will not move
I would say that the belt is broken or has came off the pulley. If you turn the hand wheel, does the needle move up and down. If it moves up and down, your problem is the belt. Remove necessary covers to access the motor pulley. Inspect, repair or replace as necessary.
Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Simplicity Sewing Machines
Need settings for Simplicity easyLock SL370 rolled hem. Machine belongs to a friend who recently moved and the instruction manual has gone missing. Thank you!
narrow 3thread seam, so remove left needle. loosen top looper tension to 3 or 2, tighten bottom looper tension to 7 or 8. thread top looper with woolly overlock thread and reduce stitch length. there is also a thread finger u need to flick back on throat or needle plate usually to make rolled hem. also move blade to right to trim less fabric as you want the fabtic to roll under inside the seam.
Apr 28, 2011 | Simplicity SL370 Mechanical Sewing Machine
Simplicity Fashion Plus breaking needles
needle guide may be slightly out of line, or bent, also chech base plate, maybe slack
Jul 21, 2009 | Simplicity Fashion Pro SW2145 Mechanical...
Simplicity so5 needle wont move
There is a device on the right side of the machine to make this work. It is either a knob to turn or a plate to push in. It is located on the right side of the machine in the wheel that turns when the machine is running. This is used to wind a bobbin. The needle doesn't run when the bobbin winder is being used,
Jan 02, 2009 | Simplicity Quilt 'n Craft S05 Mechanical...
Simplicity Serge Pro SW432 Mechanical Sewing Machine Logo
55 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
