Question about Magellan RoadMate 3000T GPS Receiver
Power pin fell off inside of Magellan Roadmate 3000T
When I went to turn on my GPS, the low power dialogue came on. So I plugged in the charger and noticed no red light or green light dtection for charging. I touched the charger cord evr so slighly and nothing. I disconnected the power cord and picked up the unit and heard a little rattle inside, like something was loose inside. I've only used this GPS possibly thirty to maybe forty occasions. I need it for some upcoming trips next month and wondered can I get it fixed somewhere, possibly an electronics repair place.
  • 5 more comments
  • PilarK Mar 29, 2008
    I have the same problem, and would like to find a way of making what should be a simple repair, hopefully without having to return to factory. Please advise!
    Pilar Kline
  • Anonymous May 27, 2008
    I also have the Roadmate 3000T, and also had the female power port break-off inside the unit. The screen display froze, would not shut itself off and eventually ran down the internal battery. Looking for a local 3rd-part repair center in the greater Seattle area. Thanks!
  • erharper18 Jun 21, 2008
    I have the same problem, no rattling noise, but the unit will not turn on and the red or green lights will no longer come on when I try to charge it. Please let me know if there are repair shops that will fix the problem without sending it back to the manufacturer.
  • letterx Aug 17, 2008
    Same problem. apiece is rattling around inside and all I have is a large hole where the powerport used to be
  • Anonymous May 01, 2009
    Same thing happened to me
  • Anonymous May 06, 2009
    suction cup came unglued and roadmate 3000T dropped on floor and electric female connection broke off. Same thing happened to a maestro 3225 that I bought for my son. the 3225 they replaced because it was under warranty but no help for mine because it is 2 years old.
  • Anonymous Mar 15, 2014
    my cobra 8000 gps is having a problem charging because inside the unit the charging plug is loose where can i have this repaired?
I managed to solder my connector back in place. The ground trace broke away from the board so I had to install a jumper to ground. I put RTV on the connector to secure it after the repair.
Worked great for a few weeks until it was dropped again and lost power, something else has a broken connection.
Posted on Aug 11, 2008
6ya staff
SOURCE:
Charger light not on, plugged into my computer Magellan 3000t
Hello :
I think you have a problem with the charging jack . If you are sure that the jack is OK , then I recommend you to replace the battery .
please rate !
Apr 16, 2010 | Magellan RoadMate 3000T GPS Receiver
Magellan RoadMate 3000T. When plugged into the cigarette lighter, I only get a little red light in the upper right corner. How do I turn it on? I can't understand their symbols. (it is a hand me down from...
Download the manual from here.
The LED in the upper right corner seems to be a charging indicator, so this means that the power supply via the cigarette lighter seems to be ok.
To switch it on, press and hold the power button for 3 or 10 seconds (depends on the state of the device - whether in sleep mode or off).
Mar 11, 2010 | Magellan RoadMate 3000T GPS Receiver
Magellan Roadmate 300T, bought new battery but it wont charge.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc powerport...i sell these power ports and will repair them for anyone thats notable to do it themselves.
you can get it repaired here
or buy the port here
Sep 03, 2009 | Magellan RoadMate 3000T GPS Receiver
Magelan freeze when powers up and shows on screen magellan
image.gifsome portion of the software Has become danaged. you may need to reinstall the system and maps from the supplied CD
Jun 21, 2009 | Magellan RoadMate 3000T GPS Receiver
Megellan 3000T - went blank
Being solid stae electronics - there is little or nothing for you to do
With this type of thing it works or it does not.
Mar 17, 2008 | Magellan RoadMate 3000T GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
I have the same issue. The device just powers up and shows the Magellan logo and does not continue past that.
Dec 14, 2007 | Magellan RoadMate 3000T GPS Receiver
Manuals
  1. You have to go get a new magellan roadmate 3000t.
  2. And that will include a manual with it.
  3. Manuals are not sold separatley any more.
Nov 29, 2007 | Magellan RoadMate 3000T GPS Receiver
Total power failure
same here! first my original car charger stopped working, so i purchased a replacement (a generic one off ebay), plugged it in and the little light on the top right turns on. but i have not been able to turn it on. i've left it charging for at least a half hour and nothing. any ideas?
Nov 24, 2007 | Magellan RoadMate 3000T GPS Receiver
Reparation
power pin probably came loose. If you can open up the unit and re-solder the power connector to the board. If you need more assistance re-post and I'll tell you in further detail. Also, make sure the end of your power cable is getting juice.. flow.. is hot? live? has power to it.
Sep 19, 2007 | Magellan RoadMate 3000T GPS Receiver
Magellan RoadMate 3000T GPS Receiver Logo
367 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
