Last night while watching TV the picture disappeared and only sound.
Turned it off, this morning turn it on and picture available for 5 minutes
then disappeared again.
Sounds like horizonal output transistor could be over heating. There could be other problems. But I would start there. You can find the part number on the schematic inside the set. If you change it yourself don't forget to use the included insulater. Part should cost between 15 & 20 dollars. You will need make & model # of set at electronic parts store.
Diagrahm inside set will show you location of transistor.
Rating Locked! (?) Tane has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on RCA F36650 36:
