Question about Coby MPC74147 256 MB MP3 Player
Blacklight? The blacklight wont trun off
0 characters
1 Points
My ipod nano was dropped in water i fished it out right away and after i dried it everything came back on and worked except my blacklight but everyhting else works fine got any ideas on what i should do
Have you checked the backlight setting in the menu options? It may have accidently been shut off without you being aware of it. Also in the future if you do happen to get an electronic device wet, you can leave it completely covered in a DRY bowl of rice over night to help pull any remaining moisture from it's circuit boards. :)
Apr 16, 2009 | Apple iPod nano
Its not working for me..!!...i tried it today and,,,,,,
Make sure that you don't have it locked .IF it is locked ,simply switch the hold button to the other side.
Aug 16, 2008 | MyMusix PD-6070 MP3 Player
Flash loading freeze
I had the same problem with mine turns out the battery sucked
i dont know if your problem is the same as mine was but i managed to fix mine by taking it apart removing the baterry and rigging up a cell battery by simply taping the bat wires on the terminals it looks pretty bat but hey for 20 mins and some electric tape what can you expect
kinda bad pics sorry i took with my webcam and blacklight
Jun 08, 2008 | iLO (2 GB) MP3 Player
When i trun it on all it dose is say internal updating music libarary and it wont trun off after you trun it on
Remove and reinsert the battery first.
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Apr 29, 2008 | MyMusix PD-6030 MP3 Player
Opal will not turn on
my thing will not trun on
Jan 16, 2008 | MP3 & Digital Media Players
Ipod wont trun off
Dec 09, 2007 | Apple iPod nano
Coby MPC74147 256 MB MP3 Player Logo
14 people viewed this question
Top Coby MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Coby MP3 and Digital Media Player Expert? Answer questions, earn points and help others
