Question about Brother HL 1440 Laser Printer
Printer not printing
HL-1440 - cartridge appears ok as is drum. Alarm light stays on. Dats light stays on. Cannot print anything at all.
  • 758 Answers
Try to uninstall and reinstall the printer...then do a test page...it should work...
Posted on Jan 05, 2008
6ya staff
SOURCE:
Data and alarm lights stay on,won't print
The Toner cartridge is empty, You can possibly take out the toner and tilt it fron side to side and maybe get a few more prints, but most likely you will need to replace the toner.
Mar 06, 2011 | Brother HL 1440 Laser Printer
1. Toner cartridge & drum warnings on, print fine. How reset?
Drum light reset:
Open front cover. Hold down button located under LED's until all LED's are lit. Release button and make sure drum LED is off, then close cover.
Dec 22, 2009 | Brother HL 1440 Laser Printer
Alarm light is on and will not print
Check your user manual .. it should tell you the probleme
based on which lights are on. You could have a paper jam, or the toner cartridge/drum may need replacing. Alternatively, some documents need you to press the print button on the printer before they will print.
Nov 11, 2009 | Brother HL 1440 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Ready light doesn't stay lit, alarm light is red
Because I was getting gray shading on my pages and data was still being printing, I decided to change the toner cartridge. Now the pages are clean and white and all the lights function properly. Most cartridges that are running on empty don't print any data at all or at least print the data at the top of the page and gradually gets fainter sp? on the page. Who would have thought just by changing the cartridge would solve the problem? So glad that's all it was........wasn't excited about having to buy a new printer.
Jul 22, 2009 | Brother HL 1440 Laser Printer
Printer not working
On this printer, the alarm and data lights mean that the toner cartridge is empty. When you replace the toner, be sure to slide the corona wire cleaner across and back. This is the small light blue plastic piece on top of the drum cartridge. You'll see a small arrow in the plastic. Just slide it back and forth once or twice each time you replace the toner cartridge.
May 11, 2008 | Brother HL 1440 Laser Printer
Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Dec 05, 2007 | Brother HL 1440 Laser Printer
i had a similar problem, but my alarm light was "only" blinking. here is what i did (and might work with your printer too): open the front and take out the drum&toner unit. take out the toner cartridge und put a little piece of paper in the hole (the one you can look right through to the other side) either at the right or left side of the cartridge. put the toner in the drum unit and then everything back in the printer. after that my printer worked and still works fine.
Feb 13, 2007 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
238 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
