Hi.
Here available codes for Sky Remote: sky remote codes
You will also need to know how to program it when you have found the code use this LINK for the sky tool when you have found the code follow this 2 step procedure.
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice. Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
3. Point your Sky remote control at your TV and press the vol + and vol -buttons. If this turns the volume up and down as you'd expect, tryother TV functions to check that your Sky remote control is now workingproperly
NO GOOD
FOR PLUSTRON
IT IS NOT A PROJECTION TV IT IS LCD'DVD 19INCH BUT THANKS ANYWAT
