Question about Garmin StreetPilot c550 GPS Receiver
Bluetoth Pairing I'm trying to pair my LG VX8700 phone with my Garmin C550. They don't see each other. Is there anything I can do?
  • 796 Answers
What u do is turn on the bluetooth on both the devices,search from any one of the device....try if u detect the device...but as u say...it should get detected without any problem
Posted on Jan 05, 2008
  • 2,427 Answers
If your doing it with blue tooth then ensure that the blue toot connectivity is on on both the phone and your system..
If it still fails to see if you might need to reset yur system and set it back up.
To reset your system
1.) unpluge the positive battery pole for 30 - 60 minutes
2.) connect it back in
3.) follow the instructions on your user manual to set it back up
I want to connect my phon by bluetooth with my comp. When I try, my phon ask cod. I don't know what this cod. Can somebody help me
its normal that pairing bluetoth need code, but dont worry you can insert code that you want, for example you insert code 1 at your phone for pairing insert 1 to at your pc ,it will work, the code you insert at phone must same as you insert at pc it will work
i hope this helpfull, if you think this helpfull please rate very helpfull
thanks for using fixya
Jan 22, 2011 | Nokia 2330 Cell Phone
Pairing bluetooth motorola W755 phone to Garmin nuvi 760
I left the Garmin in passive mode and had just the phone do a search for new bluetooth devices and it worked fine. So my advice is , if the Garmin instructions don't work, try this method.
Apr 01, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin 760 Blutooth pairing
I also have the 760 & the first gen Boulder (before the front speaker was added). I had the same issue with the M07 firmware (the latest you can get over the air), but took it into a Verizon store & updated it to M09. I am now able to pair the two devices.
Jan 04, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin c550 phone book problem
Try deleting the pair from both the phone and the Garmin.
Then, retry the pairing sequence.
Hope this helps.
Sep 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Pairing the Garmin Nuvi 660 with my Verizon LG Voyager
yes your phone will work with this unit i have hooked up plenty of them .... if you have any problems contact me and i will help
thanks nate
Aug 25, 2008 | Garmin Nuvi 660 GPS Receiver
Pairing my bluetoth to my blackberry curve phone
When it is turned off, hold the main button in for 4 seconds until the light flashes red, the release. It should flash red and blue. This means it is in pairing mode.
Aug 22, 2008 | Plantronics Explorer 340 Wireless Headset
Pairing LG VX8700 with Motorola H700
try to power cycle the cellphone by turning it off and remove battery, then reinstall and turn it back on
For headset pairing
How to pair the phone with a Bluetooth™ headset The phone identifies and maintains up to 16 devices which are displayed in a list. To add a new device or pair a headset via bluetooth, turn Bluetooth™ on in both devices.
  1. Put headset in pairing mode. See Headset User Guide for more information, if needed.
  2. Turn on Bluetooth in your phone, Go to menu, [SETTINGS] > [CONNECTIVITY] > [BLUETOOTH] and press "Select"
  3. Choose [TURN ON] , press "Select"
  4. Choose [MY DEVICES], press "Select"
  5. Choose [NEW DEVICE], press "Select"
  6. Choose the headset to be paired and press ' Select '
  7. Enter the pass key '0000', press "Ok"
Link for headset setting, just choose the headset model
http://www.sonyericsson.com/cws/support/products/pairinginstructions/w300i?cc=us&lc=en
If you are using a different device the just set the Bluetooth to on on it as well
Apr 22, 2008 | Motorola Mobility H700 Headset
Permanent Connect and disconnect with K750i
I had the same issue with my LG Vx8700 phone. Turned out to be the phone and not the parrot. Am on my third replacement Vx8700 and it is working fine for now.
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Garmin StreetPilot c550 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
