While machine is filling turn of power if the water is still entering machine you have a mechanical fault water valve hot or cold needs replacing if water stops when power turned of you ave an electrical or control problem check water level hose from tub to level switch for damage or perishing if ok check water level switch blow into it see if it clicks if not replace also while blowing hold pressure to see if the diaphragm in the pressure switch is not perished keep me informed
Testimonial: "Great information. I will helpbme locate the problem in a rather than just hunting. I will order the replacement parts and let you know"
