LaCie F.A. Porsche  Hard Drive
Problem for LaCie F.A. Porsche (301177) Hard Drive
I have a Lacie external hard drive which my Dell
By altmolec on Nov 05, 2009
I have a Lacie external hard drive which my Dell desktop computer does not recognize anymore. The Lacie's light on the front flashes (alternating) red and green. I've checked the connections and all seem to be well connected. I have not done anything to the files (such as erase, etc.), the system just stopped coming up on the "my computer" click. I've owned the hard drive since about August 2008.
Best Solution
posted on Nov 06, 2009
Very Helpful)
bob_computer
Rank: Guru  LaCie Computer Accessories  Expert
Rating: 87%, 1440 votes
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Comments:
Nov 06, 2009
- SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for LaCie F.A. Porsche Hard Drive
Questions and Unsolved Problems for LaCie F.A. Porsche Hard Drive
Do you recommend LaCie F.A. Porsche (301177) Hard Drive?
Answer
Answer
My PC stopped to recognize Lacie. I disconnected, reconnected to nioavail.
Answer
Hard drive is on, but will not open. Lacie F.A. Porche design (525 GB?). The light on the hard... (More)
Answer
My external hard-drive, Lacie by F.A. Porche 250 gb, worked fine on my HP desktop, has Vista OS, but... (More)
Answer
my PC running Window XP won't display the icon of my Lacie HD 2TB. Everytime I have to go to... (More)
Describe your Hard Drives problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drive Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
