Question about Maxtor Hard Drive
NTLDR is missing, now file pic.sys is corrupt with CD Boot... I want back in man.
"I had NTLDR is missing press any key to restart, and unable to find hard drive"..., (Dell Dimension 4500s XPpro SP2). Booting from CD leads now to "file pci.sys is currupt" and it just loops back to this blue screen in "Windows setup"!? On the drive starting with the NTLDR problemn, even with a blank replacement Drive, either or it's the same. Who's the answer. I know you? exist. Help me HAL appears drunk at the wheel.
Thanks if you (please!!!) choose to help,
Dave
Fxvgjcv
Posted on Nov 25, 2008
    Brigadier General:
  • 6,966 Answers
Try removing and cleaning your memory using a pencil eraser. Rub the eraser across the gold pins of the memory to make them shiny. Additionally you can use a soft brush to clean the memory slots. When re inserting the memory, pls make sure that they go in with a positive click.
If the above is not corrective, you may need to replace your memory.
In some instances, you may need to re partition and reformat the entire hard drive prior to installing XP SP2.
Hope this be of help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Posted on Jan 05, 2008
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Aug 17, 2014 | Computers & Internet
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
NTLDR is missing in my computer
Missing NTLDR can be caused by any one of these problems :-
With Windows XP follow these instructions
If this doesn't work, then the last resort is to install Windows again, plus the computers device drivers and your programs.
Feb 11, 2010 | Computers & Internet
Ntldr is missing press clt alt del to restart
The NTLDR and Ntdetect.com files are important system files that are used by your computer to start the Windows XP operating system. These files can become damaged, corrupted or deleted for a number of reasons and are usually brought to your attention by the "NTLDR is Missing" error message.
Follow these easy steps to restore the damaged/corrupted or missing NTLDR and Ntdetect.com files from the Windows XP CD using the Recovery Console.
Time Required: Restoring the NTLDR and Ntdetect.com files from the Windows XP CD usually takes less than 15 minutes
Here's How:
Boot your system  using a Windows XP CD, press any key when the windows display "press any key to boot from CD"and wait for some time, select "r" option to go to recovery console. it will ask you for administrator password too.
When you reach the command prompt type the following two commands, pressing Enter after each one:
copy d:\i386\ntldr c:\
copy d:\i386\ntdetect.com c:\
In the command listed above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\ represents the root folder of the partition that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite either of the two files, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that missing or corrupt versions of the NTLDR and/or Ntdetect.com files were your only issues, Windows XP should now start normally.
That's it.
Jan 22, 2010 | Acer Aspire 5315 Notebook
Whenever i switch on my system, it displays NTLDR MISSING PRESS CTRL+ALT+DEL... WHAT SHOULD I DO?
NTLDR is a file which is kept in the windows directory in the sytem32 folder, and is basically the boot loader.
Most of these problems are caused by bad BIOS configurations but sometimes the files are just corrupt.
Try going into the BIOS and setting it to default configurations, save the changes and exit the BIOS. The computer will restart and hopefully boot into Windows.
If you still get the same error message then follow this instruction bellow:
  1. Insert a Windows XP bootable CD into the computer.
  6. Copy the below two files to the rootdirectory of the primary hard disk. In the below example we are copyingthese files from the CD-ROM drive letter, which in this case is "e."This letter may be different on your computer.
    copy e:i386tldr c:
    copy e:i386tdetect.com c:
Good luck and please post back if need anymore help.
Nov 10, 2009 | Microsoft Windows XP Home Edition
I have a Epic notebook ACE 1314 model no. MS_1314 and when i turn it on it comes up with NTLDR is missing can anyone help me please? Cheers Dylan
the windows system is trashed - boot from a xp cd and choose repair -
NTLDR is Missing
NTLDR is missing
Causes:
Sep 10, 2009 | Computers & Internet
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
NTLDR is Missing
NTLDR is missing
Cause:
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Ntldr is missing, press ctrl,alt and del to restart
the ntldr.sys file is used to boot your winxp, this should have got corrupted, or your boot sector in the harddisk should have got corrupted.
what file system was used on your harddisk ( Fat32 or NTFS)
if it is Fat32 then you can try this. boot your system with win98 boot cd or floppy. after booting insert your windows xp cd in the cd drive copy the file ntldr.sys from the i386 folder to the os root dir(usually the c:) you will receive a overwrite message. do the over writing. thats all.
now restart your system normally (harddisk). it should be fine.
if the file system is NTFS, i am sorry to say, if you dont know the admin pass, you will have to repair the installation with the winxp cd,
for this boot your system with the winxp cd, on the first screen, press enter( for a fresh installation), then press F8, now you will be notified that there is already a window installation, on this screen press 'R' to repair the installation. follow the online screen.
Actually this is a nothing but just a reinstall of the OS. you may have to reinstall most of the os updates. and a few softwares also.
Hope this helps you.
Jan 09, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
What is NTLDR
NTLDR is short for New Technology Loader, an essential initializing program for Windows.NT4/2k/XP.
A missing NTLDR indicates several fault possibilities, most common are:
1. partially defective memory;
2. corrupt files or Windows installation in the boot hard disk; and/or
3. IDE cable, motherboard, the hard disk itself and others.
If it is a memory problem, try removing the memory sticks and clean the gold pins with a pencil eraser, re-install and make sure seated correctly. Reboot and try again.
If it is a corrupt file, insert an OEM Windows XP Installer (bootable) CD into the PC and when prompted, press any key to boot from CD. Once in the setup menu, press the "R" key to repair Windows. Log into by pressing "1" key and then enter.
You would need your administrator password, then hit enter. You need to copy the missing file(s) from the CD to your HD. Type :
copy D:\i386\ntldr C:\
copy D:\i386\ntdetect.com D:\
Soon as copied, reboot.
If thereafter, other files turn out to be missing also, perhaps you might be better off formatting your HD and re-installing your OS since chances are not only 1 or 2 files are already corrupt.
In some cases, even a re-install will not solve the problem, you then may either have to replace your memory or your hard disk.
Hope this be of some idea/help. Pls post back how things turn out or should you need additional information.
Nov 03, 2007 | Toshiba Satellite A15-S157 Notebook
Maxtor Hard Drive Logo
300 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
