Question about Microsoft Xbox 360 Console
My xbox 360 wireless button doesn't work????
I bought a new xbox 360 wireless controller and i went to connect it to my 360 and when i pushed the wireless button on the controller, the controller did it's job and nothing was wrong with it, but when i tried to push the wireless button on the console like it said to do=the lights on the console didn't light up around in circles or w/e like they were supposed to do. does anyone know why my xbox 360's wireless button isn't working?ppls help me with this. or at least tell me how to fix it..ty, a very mad gamer!!! lmfao!!!
  • 7 more comments
  • ljjaguar Jan 08, 2008
    I have the same problem, i just got a new box shipped from them under 2 weeks ago and today i came home and i turned the xbox on and no lights came on and my controller could not connect to it. its hard to fix anything when you can't even control anything
  • chrisduhbomb Jan 11, 2008
    yes ljjaguar, but what i'm talking about i have a brand new controller i bought from a store, and my lights on the console work but they just dont spin around like they are supposed to when u connect another controller, pls tell me if u get any help for this problem, and thanks yall other guys but i know exactly how to connect it and the controller's light do flash like they are supposed to do. but when i press the connect button on the console nothing happens. i'v e tried holding it down for(like forever) and tried just pressing it and everything but it wont work. I've played a freinds xbox 360 before so i know how its supposed to be done. it just doesn't work.. i've looked everywhere online to try to find a case like mine ,but it seems like my problem is one of a kind.. if anyone can figure out or find out how to fix my problem pls help! as soon as possible~~~~~~~~ty Chris
  • chrisduhbomb Jan 18, 2008
    well i'm thinking of sending it back and getting a new one,maybe. i was wondering if anyone knew how long it takes to get it back
    ty,chris
  • Anonymous Jan 30, 2008
    Same problem
    got it back from them
    controller button doesn't work
    ugh
  • lil_daddy4us May 21, 2008
    I bought a wireless headset for Xbox 360, but I cant get it connected because that damned button....wtf
  • Anonymous Nov 30, 2008
    i agree it won't work!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • gareth_rockz Dec 27, 2008
    My controller just flashes and does not connect. i have had it for over a year now will i be serviced a new one?
  • Anonymous Apr 06, 2009
    It's been a year since this post, but... I have the same problem. One day everything was fine, the next, my controllers won't sync, and the lights don't work on the front of the xbox. So weird.
  • alsiya May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com,
I had the same problem with my new controller. The trick is to hold the connect button on the console for a few seconds and then hold the connect button on the controller. The main part is to hhhhoooolldddd it until the ring lights up.
Posted on Jan 09, 2008
I had the same problem. You just have to buy a plug and play cord and when you plug your controller in it automatically syncs the controller to the xbox. It's like $20 at best buy and it comes with the charger cord and a rechargeable battary
Posted on Jul 12, 2008
    Scholar:
  • 128 Answers
Press both buttons at the same time next time you try. If it still doesnt work, Call customer support at 1-800-4MY-XBOX
Posted on Jan 11, 2008
  • 182 Answers
You need to press the little button on the xbox360 first then press the little button on the top of the controller its next to where you charge it. hope this helps.
Posted on Jan 08, 2008
The cable worked for me as well. Here is the detail on why:
On my xbox, I traced the problem all the way to a poor solder connection under U2C1. The switch is connected to a pullup resistor, which holds a signal high until the button is pressed. On my xbox, the voltage levels all behave as expected all the way to the other end of the 10k resistor that leads to U2C1, which means that the problem has to be either inside of the circuit board or under the chip. I suspect the chip for other reasons but am not willing to try reflowing the solder of a BGA if there is another way to get it working.
After reading this forum, I bought the play and charge cable from Best Buy today for $15 and was able to get my wireless remote to sync instantly. The connection was maintained after I unplugged the cable. Thanks for the help!
Posted on Jan 19, 2010
Same issue for me. Did all that stuff and the link cable was best idea. Thanks!
Posted on Dec 27, 2009
I had the same prob and couldn't find any advice...This MAY be your problem.
Take off the xbox's face plate (http://www.youtube.com/watch?v=cTkvZCeUAwo). Look @ where the connect button lines up. On the back of the plate you should see the backside of the button. It SHOULD be a 1/4 inch or so piece of plastic aimed toward the inside of the xbox. THIS is the part that actually physically goes in initiates (presses against) the connection inside the xbox. When I first found mine it was bend sideways (probably from jamming it in so hard lol). Just put some super glue on it and when it's completely dry, connect the faceplate so that the plastic part actually goes in it's hole with no interference. It should now work (you'll here it click like a button). Hopefully it helps!!
Posted on Aug 31, 2009
Just unplug your xbox fo 30 minutes then plug it back in
Posted on Jul 16, 2008
I have the same probelm as far as the wireless butoon on the "console". Maybe..."HOOOLLLDDDINNNGGG IT" will work. As smart as I am...didn't come up with that variable on my own...wOw with the big "O". Will post again when said theory is tested.
Posted on Mar 06, 2008
YOU have to sync the controllers you a** holes
Posted on Feb 17, 2008
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
Turbo Fire 2 controller for Xbox 360 right slick doesn't work
ok m8 visit my website xbox360repairspro.webs.com or try taking it apart and playing around with the connection to the new rapid fire button
May 28, 2011 | Datel Xbox 360 Turbo Fire 2 Wireless...
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
New Controller wont work with Headset
try to reset button on the both side (xbox and controller))
at same time it will work
for xbox reset buuton on the side censor
for joystick above the battery
Feb 13, 2010 | Microsoft Xbox 360 Wireless Controller
I can't get my remote from my old xbox 360 to work with my new 1
If wireless, then push the sync button on the front of the console and on the controller.They are located on the top and in between the left and right bumbers of the controller.
Dec 06, 2009 | Microsoft Xbox 360 Controller
Xbox wirless receiver not working!!!
Probably defective. Get you a new one.
Jul 26, 2009 | Microsoft Xbox 360 Controller
Xbox 360 Controller Won't Connect To My 360....
You have to connect the controller like this: Somewhere on the XBox 360 controller there is a button that looks like this, o))) or something like that. Push that button and look at the XBox 360 round lights, they start to flash, that means you have to push the same button on the console. The o))) button should be infront of the console.
Regards,
Max
Jul 09, 2009 | Microsoft Video Game Consoles & Games
Wireless controller
press the little buton on the controller and the xbox and it should register
Apr 26, 2009 | Microsoft Guitar Hero: Aerosmith with...
Rock Band guitar for xbox 360 stopped working
On the face of your 360 is a little round button that tells the system to search for wireless controllers. Push it at the same time you push the connect button on your guitar or drums. I figured this out after returning two other systems to Wal-Mart.... They really should put this info in the instructions somewhere! Tell me if it works for you guys too.
Nov 25, 2008 | MTV Games Rock Band Bundle for Xbox 360
Microsoft Xbox 360 Console Logo
3,774 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
