Question about Kenmore 24 in. 16304 Built-in Dishwasher
Kenmore model 665 dishwasher
On water miser cycle hangs up on 42 minutes and on quick wash
hangs up on 6 minutes and won't shut off or continue to complete cycle
  • twpeters Nov 18, 2008
    I have a simuliar problem. It will run to 52 min left and lockup. It will not
    complete the cycle???
  • 640 Answers
The timer is bad.the 42 min cycle and the 6 min cycle share the same timeline.try for the part number and price.installing the timer isnt that difficult.
Posted on Jan 05, 2008
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
Mar 20, 2015 | Kenmore Dishwashers
If the element has a thermal fuse then it may still look good even when blown. The only way to check is to test for continuity across it. Unfortunately this can only be done from where the wires are connected onto the element. The water not heating up would stop the cycle, as it needs to hit temperature before continuing the cycle. This might not be the reason your machine is stopping, but hole this answers the questions and points you have made in your post
Oct 29, 2017 | Dishwashers
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
And your manual.
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Kenmore dishwasher model 665
check for a clog at the water valve under the dishwasher.Remove lower panel of D/W(dishwasher)Shut off power supply to D/W.Remove the water supply line from your water valve(its most likely mounted underneath to the left side of frame.After removing this ,very slowely turn water back on just enough to determine if you have a clogged line. Let me know when you are there.
May 20, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Dishwasher does not wash
Stew, Im not really sure what model you have 665, 587, 363 or what. If it's a 665, it sounds like the wash motor is not getting power. Remove the toe panel and look at the start capacitor. See if one of the wires came off during the reinstallation. Should be on the left side of the wash motor. If one of the wires is off, wash motor won't run. If that's ok, check the main harness to the motor. Catriver
Sep 17, 2007 | Kenmore 15129 Built-in Dishwasher
Kenmore 24 in. 16304 Built-in Dishwasher Logo
557 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
