One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it. You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE. Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason. Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear. Known as "The Click Of Death"
Comments:
Nov 05, 2009
It may well be some form of virus or spyware.
It may also be that you have too many applications running at once eg. lots of toolbars and instant message typ programs.
It can also happen on graphic intensive applications.
From a CLEAN computer download and put on a flash drive.
Copy to your DESKTOP on the suspec computer.
Run it but dont change any options just use what it offers.
When its done let it clean anything it finds.
Its where I always start with an infected machine.
As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
It may just be a "leaking application"
These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this. .
First thought - Malware. Malware has a tendency to disable such things as flash drives and viruses especially can slow down your computer immensely. Head over to http://www.malwarebytes.org/ and download the free MBAM program on the left side, make sure it is updated once installed, and run a full scan. Tell it to fix/remove all issues and reboot if prompted. This will rid you of the vast majority of existent malware.
the computer just has humans require a program that allows it to recognize interact with the flash drive just like the guides we hire when we go for euro trip. the program here is the driver which recognises the USB.
Please check with the drivers for the e-machine pc's in the below link
http://www.emachines.com/support/product_support.html
Hope this helps
I've had a similar problem before and the issue could be a BIOS setting. Reboot and hit F2 or the key that gets you into the BIOS settings and check the USB settings. If legacy USB is enabled, disable it, and try again. You may have to try a couple of different settings before you get it. Good luck!
Was this helpful?
Yes
No
Popular Solutions for E-Machines eMachines Desktop
I need help on quicktime error 2048.
How do I repair files that give me this error message when I...
(More)
How do I repair files that give me this error message when I try to open them?
Help me! I need you solutions- sound driver for motherboad type IntelSandy Canal BLK-u...
(More)
Help me! I need you solutions- sound driver for motherboad type IntelSandy Canal BLK-u ATX-LGA775-VGA-AGP8x-SATA-LAN
thank you
cyril
