Question about Dometic Rooftop RV Air Conditioner
Hot Compressor, no Cooling
My unit is 2002 and is not cooling at all. Compressor "clicks" on and off when temp button is alternated between "cool" and "colder". The compressor gets very hot and there is no cooling at all on the lines. There are no fittings to check the pressures. What to do?
  • gherrera Mar 29, 2008
    When i turn my air contioner on, nothing but air comes out, no cold air. I replaced the compressor motor starter and still nothing. I did not how ever replace the Fan/Run capacitor because the fan is still running. I do not know what next step to take. I'd appreciate any help.
  • stan5653 Apr 16, 2008
    my camper compressor runs fine, alittle cool air comes from it but not cold, is there a way to check the freon in this unit
    Master:
  • 619 Answers
If you have clamp tester / read the label of the compressor how many amphere register give allowance 5 amphere during testing time if register for example 3 to 5 amphere the label is 3 amphere is good the compressor / but it will register 0.5 or 15 amphere or up the compressor is badly replace.
Posted on Jan 08, 2008
Not cooling. Temp readout at 22 degrees. Reset to 4 but returns to 22. Compressor sounds like it is running and is hot. Any clues?
If unit not cooling adequately the evaporator might be frozen affecting freezer and refrig temps. If frozen, the defrost timer and/or element might be kaput and need replacement. If that all checks out , if your unit has an electronic panel there could be something wrong with the temperature circuit which would entail a board replacement.
Mar 11, 2015 | Refrigerators
Why is this not cooling
Is it a portable a/c unit? Is it vented properly- out a window? Does it shut off if the drip pan is full of water?
I have a different brand portable a/c unit and find that while they say it can cool a room, I don't think it will work well on its own- a window unit would be better. I use mine in a bedroom to cool a little more than my central unit.
These units need to exhaust hot air outside the room it's trying to cool. Some will shut off if the internal drip pan fills with condensation to avoid water spilling and damaging floors.
I don't use the "auto" mode on mine, just set the temp and make sure the compressor on in manual.
Feb 18, 2018 | Idylis Heating & Cooling
Unit runs and blows air but does not cool, can it be recharged?
check to see if compressor running if ok bad cooling unit or temp sensor
Jul 03, 2012 | Dometic Rooftop RV Air Conditioner
2002 Jetta 1.8T blew 40A cooling fan fuse - overheated, destroyed 4 way cooling hose connector - replaced all- now it still runs very hot, inside temp reads 190 (but temp is much higher), cooling fans run...
Then replace the thermostat, because if on lower hose not hot and on upper hose scalding hot = antifreeze flow blocked by the thermostat wich remains closed!!!
Thermostat replacing:
Aug 27, 2010 | 2002 Volkswagen Jetta TDI
Keeprite 2300 sx a/c w/ 2 speed fan never seems to go high speed .should I be able to hear it change and how do I dainose the problem ? and does this cause poor cooling ? the compressor unit line is cold...
I need more info. I can't seem to find your indoor unit. Is this a 2 stage cooling unit or just 2 speed fan? Please send the model number of your indoor unit.
Apr 11, 2017 | Heating & Cooling
Our danby dwc 283bls is not cooling. The motor
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
Fridge not cooling all temp display works but not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ytihfdmh
May 20, 2010 | Whirlpool GS5SHAXN Side by Side...
Compressor working, cooling coils hot, but unit won't cool below
When you say fully charged, did you weigh the refrigerant? These small systems cannot tolerate overcharging by even small amounts because it will result in overpressure on the suction side. If there's too much refrigerant you get hot coils and cool but not cold evaporator. I typically pump the refrigerant into a recovery tank and then weigh it back in to get exactly the amount on the mfg label.
Dec 12, 2009 | True 598-TSSU608ADA SandwichSalad Unit 155...
Amana side by side compressor not running
Cleaning the fins is always good. Is the fan by the compressor running? It needs to help cool the compressor. The description you mention sounds like the compressor is overheated and tripping the thermal overload on the compressor. See if you can turn if off for a day to let it all return to room temp then see if the compressor kicks on. If it was overheated it should run again for a while before overheating again. Let us know how that works and we can go from there.
Nov 29, 2006 | Amana ASD2326HE Side by Side Refrigerator
Dometic Rooftop RV Air Conditioner Logo
231 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
