Question about Logitech Z-2300 Computer Speakers
Popping in left speaker only...
I just bought the Logi Z-2300. I've noticed that even at lower volumes, the speaker hooked up to the left channel pops alot, while the one on the right channel is clean and clear.
I exchanged it for another set of the same speakers, and I'm having the same problem. I'm using onboard sound on my Asus M2N-SLI Deluxe board, which worked fine with my last set of speakers (old Altec Lansing 5.1 set).
Is anyone else having this problem? I find it odd that it's only the left channel that's popping and not both channels, and that it's happened in both sets I've bought.
I really want to hang on to these so if anyone can tell me what's up it would be greatly appreciated!
  • Rhizo Feb 06, 2008
    I ended up picking up the SB Audigy 4 soundcard for my Pc and it made all the difference in the world. I figure the popping was caused by a dirty signal from my onboard sound.
Posted on Jun 17, 2008
  • 983 Answers
Just go master volume control and check whether the left and right speaker sound is in balance that is balance must be in middle... i think this audio property may have be changed
Posted on Feb 05, 2008
I can't get my rear left speaker to work for my LG LHT854
you bought it new ... every new prodycts should come with warranty therefore best advice take it down to where ever you bought it from
May 30, 2017 | LG LHT854 Theater System
I have actually lost my satellite speakers that came with the Logitech Z-2300. I am wondering what my best option is. I can't seem to find anyplace that sells these kind of speakers separately. I...
It would appear you need 2 x 1/4 inch (3.5mm) jack to RCA cables, one for each channel and each speaker, left and right, rather than just the 1 cable ("..and a mini to RCA cord...") you seem to have bought.
The Yellow and Black RCA ports appear to be the Left and Right speaker channels respectively.
The output cable with a green jack that connects to the green jack on the computer's sound card seems to be tied in with the wired Remote Control.
I would have recommended getting a pair of passive 40W RMS Logitech Stereo Speakers.
As long as the speakers you have match in terms of Wattage and Impedance, you should be okay.
I hope this helps.
Aug 26, 2011 | Logitech Z-2300 Computer Speakers
I have the logitech z-2300 just the other day the
mine did the same thing today , i just bought these new 2 weeks ago . the black prong speaker works in both ports ..
the yellow prong speaker is the one with the malfunction .
it works sometimes but when i turn up the volume louder it dies out .
Feb 23, 2010 | Logitech Z-2300 2.1 Computer Speaker...
Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
Feb 05, 2010 | Logitech Z-2300 Computer Speakers
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
Asus A8N32 SLI Deluxe Motherboard audio problem
The new boards multiplex the connectors on the back panel to maximize use. Open the Realtek control panel and configure for sterio 2.1. Also, these new boards do not provide any power drive, so to get decent volume, you will need amplified speakers.
Oct 09, 2009 | ASUS A8N-SLI Premium Motherboard
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
Left Speaker Problem
Sounds like the left channel in the built-in amplifier went out or possibly damage in the connector or cabling. Quick test to eliminate the PC is to connect another set of working speakers or headphones into the PC speaker jack without making any changes. If it works w/o problems then it?s the speakers. You can try plugging the speakers back into your PC and while playing something start wiggling the left channel cables and the main cable that goes into the PC. In particular pay attention to stress points like connectors. If that turns up nothing and you have the appropriate tools and skills you can open the speakers up and test out the solder points for the cables as well. As always make sure your warranty has expired completely before you open them up or start cutting away. Let us know if you have any other questions and please don?t forget to rate this post.
Apr 12, 2007 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
415 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
