knpeterso548, I wouldn't even worry about that little power "ON" indicator light. As long as the button functions as an "on" or "off" switch, you will only need to remember to turn sleep mode setting to total "off" mode (disable) in the pc. This way you will need to turn off the monitor with the BUTTON when you will be away from the pc for more than 1-2 hours. Face IT!!! Even I would charge you $15 just to open it up! $10 for a new "on/off" switch/with led and then $10 to put it all back together again. Give a call to HP (High Price) and find out what they will charge for replacing a switch. As long as the LCD panel displays brite, crisp images and text, you are way better off than those who don't see a thing on their LCD screen when they press the power "ON" button.
Bye for now. 12fix louie
Hi, My monitor flickers on then off at intervals where off is longer than on. this is a consistent...
(More)
Hi, My monitor flickers on then off at intervals where off is longer than on. this is a consistent patern in terms of time.
hp monitor is in constant sleep mode...cant check the settings because the screen is black. Any...
(More)
hp monitor is in constant sleep mode...cant check the settings because the screen is black. Any suggestions as to how to wake it up? Have rebooted and checked all connections.
