Hi! ricoh digital 6513. sc 458 ? thank you
  • trieu Jan 07, 2008
    thank you
  • 417 Answers
SC458 PTR pressure
mechanism H.P.
detection error
• When the PTR pressure
mechanism does not
stop its H.P. after 15
seconds from the PTR
lift motor starts to return
to its H.P.
• H.P. detection sensor
does not on within 7
seconds after the PTR
pressure movement
starts.
does not off within 7
pressure release starts.
• Defective PTR lift motor
• Defective H.P. sensor
• Dirty H.P. sensor
feeler
• Defective main control
board
1. Make sure that sensor harness is properly
connected.
2. Clean the sensor, replace it if necessary.
3. If the sensor feeler is broken, replace it.
4. Replace the PTR lift motor.
5. Replace main control board.
Hope this is what your looking for
Thanks J
Posted on Jan 06, 2008
Functional problem SC 500
sc-500 is very often no motor or PCU problem. The driveshaft wich operate the PCU is often inoperable throug dirt, "hardend" grease....
Cleaning it & Oiling it with silicone-based oil will do the trick
Sep 13, 2011 | Ricoh 6513 Copier
What is the sc 422 error on a RICOH AFICIO 6513?
SC422 PCC leak - Timing & Condition -
When the current leak is
detected for 2 seconds,
and the leak detection
started 1 second after the
PCC turned on. This leak
signal is monitored twice a
second. If it is detected
twice in a row, this SC is
displayed.
• PCC unit not properly
installed
• Broken corona wire
• Defective high voltage
supply board
(T1/PCC/BR)
• Defective I/O control
board
board
Sep 02, 2011 | Ricoh 6513 Copier
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
Ricoh colar 6513 cod sc 457
SC457 mean Image Transfer Belt Cleaning Unit Position
Error, try to clean the sensor in the transfer belt with a dry cloth.
Jun 21, 2010 | Ricoh 6513 Copier
Ricoh 6513, service code 551
SC551 is thermistor pressure roller error. Check for paper jams in the fuser. It could need a new thermistor.
Make sure the fuser is secured and properly seated in the copier.
Jun 12, 2008 | Office Equipment & Supplies
Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
May 24, 2008 | Ricoh 6513 Copier
Ricoh 6513 streaking
Depending on your use IE lots of thick paper 150gsm plus.
The fuser rollers wear very quickly.
There is no Cheap fix for this.
These machines are very costley to run.
Ricoh Tech L3 22 years exp.
Mar 21, 2008 | Ricoh 6513 Copier
Ricoh 6513
A sc541 code is with the fixing ass'y did you try to reset it? Did it come right back? Is the fuser warm to the touch? If so it is most likly to be one or both of the termister in the fuser. If it is cold it may be the fuser heatting lamp or thermal fuse
Feb 08, 2008 | Ricoh 6513 Copier
Hello !
Hello trieu. I would and will gladly help you if you could provide the make and model of you copier. This is very important in order to provide the correct answer. Sc 458 means one thing for a Canon machine and another for a Ricoh or Zerox. Please let me know so I can help.
Jan 05, 2008 | Office Equipment & Supplies
185 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
