Question about RCA DRC220N DVD Player
My RCA DRC 220 Dvd Players disc tray does not want to close
Though I have had this DVD Player for a while it actually has not been used much for being on a tv rarley used. Yet, the last few times I have used it the disc tray door does not want to close. It luckily closed so now it not sticking out. What is going on?
  • 1 more comment
  • Anonymous Jan 09, 2008
    My problem is the band on the motor pulley. Do I have to use any special rubber band for this?
  • Anonymous Mar 31, 2008
    I had watched a combination of problems. 1st. the tray open but it doesn't close totaly, but with a little help with the hand it colse. 2nd. when It close appear the message "no disk" but it is because the lens is not in the right horizontal position but I tryed to push to up on bottom of the board of lens at the horizontal position to read the disk and I get play the disk.
    Now, I don't know if the problem is mechanical or electronic.
    Why I can get to play the disks only with hand help. What I have to fix.
    Thanks
    Byron
    GUATEMALA
    [email protected]
  • shannon3boys Dec 09, 2008
    we are having the same "no disc" problem with ours, did you ever get a solution?? im wonding if there has been a recall!
  • 2,427 Answers
It seems that the track (carriage) is proberally damaged or needs cleaning, open it out and have a look at the track that takes in the disc if it has dust clean it out or you can open and close it bu hand to get it loose a bit.
If that dont work the motor that pulls in the track or sends it out has a band on it, it might be slack or worn or even dried up and lost elasticity, test it by pulling it in and out a few time to see if it snaps, if you think its worn are slack replace it with a rubber band or a smaller size to the band...
the last think to check is the motor it self.if the abose fails you'll need to change the motor
Posted on Jan 05, 2008
6ya staff
SOURCE:
Rca dvd player stuck
There are a number of possibilities, jammed gears caused by a disc or gears out of time, some have a very small loading belt located under the draw in most cases, excessive ware and tare on plastic gear linkage.
Sep 05, 2012 | RCA Televison & Video
RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Aug 22, 2007 | RCA DRC-285 DVD Player
RCA DRC 8052NB will not read discs
This sound like a problem with the laser read circuits and it may be solved with a simple cleaning and using compressed air to clear the unit of debris .To do this you must take off the top cover of your unit by taking out the screws and lifting the top off. To clean the laser head you should use cotton swabs and isopropyl alcohol. put a small amount on the cotton swab and rub the swab gently back and forth over the head, until it seems bright and shiny.Check the transport carriage for dust and debris and also the gears. all these must be clean for proper operation. You may want to put a little lithium grease on the gears and guide rails for smooth operation. All this should be done in minute amounts so you do not over do it and cause more problems. If all this fails to allow you to use you disc player, Then you probably have a worn out laser sensor and will have to have it replaced. If under warranty send it in and if not try to find the part number and order it and either take in to a service center for repairs or do it yourself. Hope this helps you with your problem.
May 15, 2009 | RCA DRC8052N DVD Recorder
DVD will not play a disc, when you close the tray, it will eject
Bad Disc.
Try a known good store bought Movie in player?
Still Bad Disc?
DVD unit in your player is bad.
Throw in garbage.
Feb 19, 2009 | RCA DRC8320 DVD Recorder/VCR
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
I have an RCA DRC 8300 combo VHS and DVD player and the DVD won't open when I press the open/close button. I know there is no DVD stuck in there and the manual doesn't help. Any suggestions?
I met a lady with the same problem.  I had to open the unit (use caution/check warranty) and I found out the foam pad that holds the discs in place fell off of its holder.  If you place this back on, the unit should work again just fine.
Oct 19, 2008 | Televison & Video
Language Selection for RCA DRC 220N
try to find an original remote in a pawn shop, sometimes they have extra remotes because broken dvd players, or other reasons they only know.
May 04, 2008 | RCA DRC220N DVD Player
RCA DVD player model DRC285
try sticking a knife on the top of the dvd slot. don't put a lot of pressure to break it though. turn the dvd player on, and it may open. If this solves the issue, try not to put items on top of the dvd player because it will cause it to stick and not open.
Apr 02, 2008 | RCA DRC-285 DVD Player
RCA DRC220N DVD Player Logo
545 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
