Hello, 1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN [COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12 Close the right parenthesis ) Screen shows cos(12) 4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1) arcsin [SHIFT][SIN] (sin^-1) actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results. Hope it helps.
There is a line in the screen where no pixels are showing, is this fixable? - it is across the whole...
(More)
There is a line in the screen where no pixels are showing, is this fixable? - it is across the whole screen.
i cant see the last 3 digits on the calculater. the numbers there are blurry [only last 3 digits. is...
(More)
i cant see the last 3 digits on the calculater. the numbers there are blurry [only last 3 digits. is it a battery problem or do i need to buy a new one?
