it wont turn on its stuck on stand by any suggestions?
when we do get the tv turned on we cant knock it off or it takes hours of fiddling with the remote standby button to get it back on the tv is a thomson scenium 42 inch rear projection tv
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
thanks will try that thank you :))
" - crabpaste4
Popular Solutions for RCA Scenium D40W20 40 in. Rear
I can't open my tv the Green button is flashing and turn off immediatly ? Wich piece should I...
(More)
I can't open my tv the Green button is flashing and turn off immediatly ? Wich piece should I replace ?
Does dust accumulate on the inside of the screen reducing vibrancy & can the screen be...
(More)
Does dust accumulate on the inside of the screen reducing vibrancy & can the screen be removed to clean? (Pertaining to RCA HD50LPW164).
