Question about Garmin Nuvi 660 GPS Receiver
Screen Brightness Plugged in Vs. unplugged
I have a nuvi 660 and the screen is brighter when unplugged and when you plug it in to power the screen dimms. I have not been able to figure out how to resolve this problem.
  • 35 Answers
Well sir its very easy , did you read your manual.
Increase your birgtness with the proper way. Everyhting is there.
Your set up is rprobably set to be dimms after 10 or 30 seconds.
I set mine to off . And no dimms.
Read the manual carefully and you will love your unit 660.
----> http://www8.garmin.com/manuals/1262_OwnersManual.pdf
Best regards
Posted on Jan 21, 2008
Garmin 1200 screen is too dark to read when plugged into my car with the supplied Garmin connector. When I unplug from the car and turn it on the screen works, plug into car doesn't work. I just was on a...
I would go to Tools....Settings...Display.... check your Color Mode is it check on Auto...Daytime or Nighttime pick one then press OK
On the Brightness press it to set it brighter or darker then press OK
Oct 30, 2010 | Garmin nuvi 1250 Car GPS Receiver
The screen brightness changes due to plug in or battery power
This is quite common actually I see it a lot. There really isn't any reason, it seems that when on batteries it trys to save power by Dimming Down, but it often just mucks up.. I always now set it via the keyboard keys. whenever I change from power adapter, to battery.
Feb 10, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
I have a nuvi 660 that just comes up woth black screen
hey i have nuvie same problems plus keyboard fubby numbers all i did was plug usb into it and computer done virus check on nuvi folder in my computer unplugged it brand new back to normal hope helps
Jun 15, 2009 | Garmin Nuvi 660 GPS Receiver
The screen is darker when unplugged
On your laptop there should be key combinations to change the brightness of your screen. Once you do this, it will stay that way for each mode until you change it again. There should be in blue above the arrow keys, the F keys, or the number keys, a symbol that indicates brightness; one key for up and one key for down. You press the FN key and that corresponding key to turn your brightness up or down. Once you got it set, leave it. It will stay that way until you change it again.
Thanks and please take a moment to rate as fixya.
Nov 08, 2008 | Computers & Internet
Screen shuts off within 10 seconds after turnon, if power not connected to car
replaced battery. works fine now. holds charge for some six hours or more.
Oct 07, 2008 | Garmin Nuvi 660 GPS Receiver
Screen appears "foggy"
have you cleaned the screen with cleaner ? cleaners will damage the screen leaving it looking foggy always use screen cleaner and never window cleaner.... also try turning up the brightness level on your unit ...... if you have someone wash your car remember to tell them no window cleaner on the gps
Aug 26, 2008 | Garmin Nuvi 660 GPS Receiver
Screen Brightness, battery is brighter then when plugged in.
mine the other way round, brightens when plugs into power source, but only marginally, enough to notice it though.
think is probably a characteristic of the electronics
Jan 26, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
New GARMIN 660 Won't get past the Intro screen
Problem solved: I got through to Tech Support. They suggested a 'hard reset', which solved the problem: Put you finger on the lower right screen while you power up and it will do a hard reset---and it will get past the "loading maps" screen, where it had been stuck.
Dec 25, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
95 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
