APC Back-UPS ES 725 Broadband  UPS System
Apc surge protector and battery backups
posted by lanaember on Jan 05, 2008
Can you use these battery backups with other products besides computers? For example, my father has a bariatric bed (a special bed that needs to be plugged in to stay inflated), and I am worried about what will happen if the electricity goes off. Can I plug the bed into the APC Surge Protector and Battery Backup (series 350)?
Comment posted on Jan 06, 2008
Thanks. That's what I thought. I'm trying to locate and speak to the manufacturer because I cannot believe they wouldn't have some kind of solution to that situation; not that the electricity goes off that often...but...
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 05, 2008
Helpful (85)
johnychel
Rank:Wiz Wiz
Rating: 75%, 149 votes
you have to have the power rating rated in amps of the bed...if the rating of your bed and the system are same or even less than that..(i.e. the rating of television is less than that of computer monitor,so u can connect tv for long time than monitor when power goes off ) then u can surely use it.....but it ll provide the supply only till the back up is stored in the battery,when the power goes off
Rating Locked! (?) lanaember has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on apc surge protector and battery backups:
I don't want to Accept this solution
Can you Help with these UPS Systems Devices problems?
UPS Systems Devices
I lost the wire that plugs into the wall and connects to...
UPS Systems Devices
i have installed suze 10. linux on my laptop but it can...
UPS Systems Devices
eurovox max
UPS Systems Devices
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll...
APC Back-UPS ES 725 Broadband (BE725BB-TU)...
Constant alarm when on battery and mains. Meanwhile the...
Loading problems.
Repair Service
Find UPS Systems Device Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
