Question about Toshiba 50H81 50" Rear Projection Television
Indentifying fuse type on tac0151 chassis
Yes we just picked up this set and was told it lost picture and sound after a power question is: there are 2 fuses on front portion of main board that are blown and are designated as f850 125v 5A, F851 125V 5A,on the board. they are pigtail type but are rectangular black plastic with soc 5a stamped on them. are they thermal,quick blow, ic protectors or what i just cant seem to find these anywhere to replace the blown ones and i am not just going to replace them with the glass 5amp without knowing just exactly what belongs there.. can you please help with this? thank you for all help. donna
  • 71 Answers
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Posted on Jan 05, 2008
Se47fy19. Has sound, but why no picture?
as there are 2 completely different circuits for sound and picture in a tv set it is possible that the picture board has been damaged by the power surge . it could be as simple as a blown fuse for that board or you may have to take it to a repair shop for a proper diagnosis and a quote
Oct 11, 2015 | Seiki Televison & Video
Where are internal fuses as have no power when plugged in?
There are several types of internal fuses. sounds like the ones you are looking for are related to providing power to your unit. IF you open up the chassis and follow where the power cord attaches - it will lead you to the power supply board where there are often removable fuses that protect the internals for power surges. Some components actually have these fuses accessible from the outside either integral to where the removable chassis power cord connects or in a fuse holder that unscrews.
Make sure you replace with the same type of fuse!
May 11, 2014 | Yamaha RX-V430 Receiver
Pioneer VSX-94 lost sound
The surge probably affected the power supply. The UPS only maintains operation for a limited time in the event of power loss.
Mar 30, 2014 | Pioneer Audio Players & Recorders
Lost our power and now it won't turn on.
Yes , usually you will need the manual to know how to replace it
In my experience the fuse blow due to something that is electrically faulty in the unit and changing the fuse does not remedy the issue. You may have a power supply issue that a reputable service tech will have to determine if it is malfunctioning in this area.
Jun 18, 2010 | Lexmark X2500 All-In-One Printer
It powers up but no picture? In my experience with Hitachi TV's this has been an issue with the convergence IC's failing. You will need to have a technician replace those if needed.
Jul 23, 2009 | Hitachi 53FDX20B 53" Rear Projection...
surge can come in thru antenna circuit ck outlet with lamp. otherwise need tech.
Dec 02, 2008 | Mitsubishi CS-40707 40" TV
Power problem
If you don't have any indicators working, you have probably lost your power supply. With no picture and no sound the chances are you have either lost the power supply or blown a fuse. If you remove the cover and look at the circuit board there is a fuse located near the rear of the chassis near where the power cord connects to the chassis. If the fuse is blown, it is advisable to replace your damaged power cord before replacing the fuse. The cord could have a short and this could create a fire. Be very careful when working on any television. Be sure it is unplugged for more than one day to allow the high voltage to decay from the picture tube. Do not touch the picture tube, it still may have some residual voltage and could shock you. If you replace the cord and fuse and still have the same problem, you will probably find that the high voltage transistor is bad and needs to be replaced.
Nov 07, 2008 | Philips 36PT842H 36" TV
Power is on but no picture or sound
Check the solder connections on capacitors C809 and C810 they are located on the left side of the chassis looking in from behind also check fuse FL860 as the solder joints could open that fuse. usually when the power led lights but the set wont power
Oct 16, 2008 | Televison & Video
Power problem
What is the chassis number to your set. Have to go by chassis numbers on phillips/magnavox and RCA tvs.
Feb 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
