Question about Sony STR-DA3ES Receiver
Remote Volume Control Not Working
I have a Sony STR-DA3ES receiver that has been working great. Then one day, I noticed that the volume control would no longer increase or decrease the volume by the remote. Then, without doing anything, it would come back and I could control the volume by remote. Now, suddenly, it appears to no longer respond at all.
I have determined that it is not the remote since the remote works with other Sony receivers I have. I have also changed batteries. I have also unplugged the receiver for 30 seconds, I have also removed the batteries from the remote and double clicked on each control button (as suggested).
Still no response.
I would be ever so greatful, given that I am semi-disabled and cannot easily get around, for any solutions to this problem. I cannot afford an expensive repair and would in no way be able to afford a new receiver - all I have coming in is SSDI.
Thank you for your consideration,
Mike
MEtten,
Flip the top cover, just above the "AV MENU" there is a round boll kind of switch, it has to be pressed when you want to function top cover button, so may be it is warn out or the nob has been broken. if you press that switch with pen nob it will function...
It is bad design...
Surendra
Posted on Mar 13, 2008
I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Jan 10, 2013 | Audio Players & Recorders
Volume keeps going up by itself
you have a bad ground in the volume knob. first take the knob off and there should be a nut that tightens. tighten if loose. if not spray w-d 40 or any kind of penitrating oil on the nut and around it. it will not mess it up,ive done it several times. the worst it could do is not fix it.
Feb 10, 2011 | Sony STR-DA3ES Receiver
When I put batteries back in remote control it automatically turns volume down, when I take batteries out everything seems to work OK manually
It seems like the volume button is stuck on the remote itself. If you can, try and clean the remote and see if you can free that button.
Jan 07, 2011 | Sony STR-DA90ESG
Speakers stop working
This is either a loose connection internally or a dirty control such as the volume control. Both of these will require a trip to the shop
Apr 04, 2010 | Sony STR-DE697 Receiver
Volume Control not working via remote. Works manually. Is there a motor or belt involved that may require replacement?
Please check volume button works on remote? Take any digital camera / mobile phone camera and see remote front through camera and press volume buttons, if you see IR LED blinking then remote is fine and amp has problem with volume. Let me know exact model of Sony amp to see its schematics.
Jun 05, 2009 | Sony STR-DE935
My Sony STR - DE310 flashes PROTECT
remote volume control is broke.
Dec 22, 2008 | Sony STR-DE310
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Sony STR-DE635 Receiver-no sound at all
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
Sony STR-DA3ES Receiver Logo
376 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
