Question about Sony PS-LX250H Turntable
Turntable ps-x55 / arm want move stay in lock mode
Hello . i have a sony ps-x55 turntable computer controlled . the arm want move the lock mode stays on..what is the problem? please let me know. thanks .Bemeche
I have the exact same problem with my TT - a PS-X55. It appears that the motor has failed. Too bad, as I was told the replacement motor part is no longer stocked by Sony. For what it's worth - the part number is 154116500.
Let me know if you manage to find some who has the exact part stocked.
Posted on Feb 26, 2008
How can I get a manual on how to fix this item? The arm needs adjusting. Thanks P.S. its a Technics sl-dd33 turntable
Technics website may have one. The counter weight has a setscrew on it. Loosen it ans move the weight slightly forward until the needle just rests completely in the groove and stays there. Too much will cause excessive wear to the needle and the record.
Aug 08, 2015 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Sony turntable ps-lx250h won't stop turning it has to be unpluged. what do i do?
When the arm moves it contacts a switch which should start and stop the motor. Clearly this switch has broken and the contacts are now in the on position.
Jan 18, 2014 | Sony PS-LX250H Turntable
Sony PS-LX55II Tonearm Doesn't move when playing
Is there an antiskate or skew adjustment and also a way to set that counter weight? If any of those are wong then it wont work
May 11, 2013 | Sony PS-LX250H Turntable
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
Just received our Sony PS-LX300USB turntable, but cannot get the stylus to stay on. Any suggestions on how to install the stylus?
Hold the stylus at an angle, rear up/needle down. Put the rear of the stylus in first and then push the front of the stylus up and clip into place.
Which stylus number did you use?
D.
Nov 09, 2010 | Sony PS-LX300USB Turntable
Sony Stereo turntable system PS-X55 Power failure
i used to own one of these? had it for 28 years and it was brilliant but temperamental during use. it sounds like your direct drive motor has given up the ghost ............so to speak? its unlikely you will be able to purchase a replacement due to its age? if you in the market for a classic retro quality replacement try this company?
http://www.retrohifi.co.uk/
Jun 13, 2009 | Sony Audio Players & Recorders
Turntable stylus not staying on record
Since there are no tonearm adjustments the only solution in the manual that comes close is to make sure the turntable is level. The other possibility is the no-brainer of checking the stylus cover is NOT rotated down, preventing the stylus from contacting the record.
A quick and dirty test of tonearm balance being too light would be to unplug the power and manually move the tonearm over the platter. Gently lower it to see if it floats in the air or lightly but firmly contacts the platter. That won't tell you if it is tracking properly but it might indicate or eliminate tracking force as the culprit.
Apr 26, 2009 | Audio Players & Recorders
Turntable swingarm skips to last song
Most likely your stylus (needle) is bent, broken or missing. Check to see if it's there or not. If it's broken or damaged, you will need to replace it. Under the cartridge, you should see a small arm that has the actual diamond on the end of it. If the arm is there, but the diamond is missing off the end, the arm won't stay in the groove and will instead skip across the record to the middle.
Mar 01, 2009 | Sony PS-LX250H Turntable
Won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Jun 04, 2008 | Sony PS-LX250 Turntable
Sony PS-LX250H Turntable Logo
764 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
