Home | Canon | PowerShot A620 Digital Camera | No image on lcd for tak...
Canon PowerShot A620 Digital Camera
Problem for Canon PowerShot A620 Digital Camera
No image on lcd for taking pictures. Lcd works
By ironhorsefx on Nov 05, 2009
no image on lcd for taking pictures. Lcd works fine to go through also to view old pictures. just black in camera mode. Tried shooting anyway and no picture. This happened once before and went away an hour later. this time it is not going away.
Solution #1
posted on Nov 07, 2009
Not Rated)
t00nz
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 91%, 1987 votes
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A620 Digital
Questions and Unsolved Problems for Canon PowerShot A620 Digital
Do you recommend Canon PowerShot A620 Digital Camera?
Answer
Answer
My camera has a white speck of dirt underneath the first lens, and does interfere in pictures and... (More)
Answer
camera used in light rain, flash banged and quit, works otherwise is it possible to fix myself with... (More)
Answer
the date stamp is turned off and on the menu screen I cannot scroll down to the date stamp to check... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A620 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
