Question about Toshiba 50H13 50" Rear Projection Television
Does not power on
I have a Toshiba 50H13 and with it pluged in directly to outlet it does not power on. Have check fuse and the fuse is good has votage thru the fuse
Also Is there a wiring schmatic for this set?
Steve Hall
  • Toshiba Master
  • 8,617 Answers
You can get a service manual by going to this link and entering your model number. http://www.servicemanuals.net/
You should check the horizontal output transistor and low voltage regulators first. Unless you have some experience in basic troubleshooting, you should be warned that you can still get shocked even after the television is unplugged.
Posted on Jan 05, 2008
  • Sonny Berry
    Sonny Berry Jan 05, 2008
    Sorry I thought they would have it. I did locate one for you here at this link http://www.smshop.org/ It cost 24.95 on CD do a search for your make and model and it will pull up Toshiba disc 18 and if you click on the disc 18 it will show you the various models on the disk. Your model is listed. Hope this helps. Let me know if I can help you further.
05 honda accord have no power in the cigarette lighter and power outlet
Well... because there can be several things that cause this issue, you want to start with the process of elimitation. Is your car powered on when you try and use the outlet? Most veichels will not allow power to the outlets when powered off.
Observe the outlet and remove any foreign objects from the outlet, there may be a fuse or metal from a broken acessory stuck in the outlet.
Start by pluging something that works into the outlet (like a cell phone charger wit an led to indicate power) locate your veichels fuse box as per instruction of the cars manual. Remove fuse cover and locate the fuse location of the outlet in question, often labeled power or accessory. Observe the ratings of the fuse and be prepared to replace it if need be (it's good to keep common spare fuse for your veichel in your glove,trunk,ect). Remove the fuse and use a fuse tester to test the fuse or look to observe if the fuse is blown, if so replace the fuse, if the led on the charger plugged into the outlet emit's light then you have solved your problem, and if not stop work and call a mechanic or post another question. There are other things you could do but nothing that I would advise without you asking.
good luck and thanks
Questions? Just ask! Mr.Mike
Nov 17, 2015 | Honda Cars & Trucks
I pluged in a small car vac in the power outlet , after ten minutes it blew. Owners manual dosen't say there is a fuse for it.
There should be a cig lighter-accessory relay in the box near the battery. It is powered by a 9amp fuse and a 20amp fuse. The 20amp fuse is in the same box with the relay.
These fuses and relay power the front and rear outlets.
Dec 21, 2012 | 1999 Dodge Caravan
Toshiba 50h13 wont turn on
Follow the voltage into the set, this kind of damage can be hard to find in any other way.
Nov 28, 2012 | Toshiba 50H13 50" Rear Projection...
Toshiba 62hm94 pluged in but getting no power at all. No green or red light on.
Hi:
CHeck for open line fuse you may of had a surge that blew the fuse especially when there is no power indication at all. IF no fuses are blown on the power supply then suspect a faulty power supply circuit.
Aug 24, 2010 | Toshiba TheaterWide 62HM94 62" Rear...
Pops power supply fuse when I plug it in
Check to fuse box to see if the fuse is working properly. Next, see if the TV "pops" the power supply when pluged into a different outlet in a different power supply area. If the TV works without poping the fuse, the fuse with the original outlet needs replacing. If both outlets "pop", either the electrical system needs checking. Or if this is a new problem that started when you first tried the TV, the TV could be wanting more power than the electrical system will allow. Check the power requiremnets in the TV manual.
Jul 28, 2009 | Recoton Advent Advent TS2066A TV
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Toshiba 50h13 hyperboard
http://www.hdtvoice.com/voice/showpost.php?p=122387&postcount=7
Oct 16, 2007 | Toshiba 50H13 50" Rear Projection...
Deteriorating picture quality at power up
It sounds like you need a hyper board for this. This part may not be available form Toshiba but I think I still have some in stock. You will likely have to have a technician insatll this for you.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Aug 27, 2007 | Toshiba 50H13 50" Rear Projection...
Toshiba 50H13 50" Rear Projection Television Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
