Question about Dryers
Dead dryer I bought a used Maytag dryer from an appliance store a few months ago. I have already had the heating element replaced. I was drying clothes and in the middle of drying it just stopped working. I can hear the timer when I turn the knob but other than that it does nothing. It might just be too old. Help!
  • 33 Answers
Usually when the thermal fuse goes bad the dryer will not respond to anything but your job will be to remove the back panel and test the fuse with an ohm meter it looks almost like your old glass auto fuses about an inch - inch and a half except its probablly black or gray or any color it will have a terminal on each end test both sides with an ohm meter if this goes bad theres probably a blockage in the vent that can also cause the heating element to die prematurely.
Posted on Jan 05, 2008
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
Not getting hot
  1. There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  2. Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  3. Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itse
  4. When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  5. please comment on there by rating or voting how helpful.
Dec 23, 2010 | Whirlpool Dryers
I have a may tag performa gas dryer. When I start it, it spins and heats but it spins very slow. I opened the top and checked the belt and it was tight and does not appear to be slipping. Is the motor...
  • There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  • Bad Heating Element
  • Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  • Broken Motor
  • Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
  • Bad Switch
  • When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  • please stay how helpful it
    Dec 21, 2010 | Dryers
    I have a neptune dryer I bought from a used appliance store about 6 months ago. The cycle comes on but there is no hot air. Clothes are not dry after 3 full cycles. I am not even sure if its gas. Don't...
    you will need to get behind the dryer and disconnect the vent tube, try drying a load of clothes with the vent tube disconnected if it drys then the tube is the problem and needs to be cleaned out. If it is not drying at all then it is a few things, I am assuming its electric here is a website that will help:
    http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
    Nov 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    Our dryer stopped heating up and will not dry clothes
    tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
    Apr 12, 2010 | Maytag SDE3606A Electric Dryer
    Dryers I have a Maytag electric Dryer, that...
    you may have one of ur overheat sensors going out that wont let the elements heat uplike they should they are behind the back cover they are round and very inexpensive u can take the wires off put new one in or u may have a bad element ake the wires off and check continuity thru the element itsself if all that is good take dryer vent off and run with it off 1 load and seee if this cures the problem if it does u had the hose kinked or u have a restriction of lint in the dryer vent going outside hope this helps
    Feb 25, 2010 | Maytag Neptune MDE6700A Electric Dryer
    My maytag neptune dryer is not drying/ what do I do first
    to check the element you need a continuity test this test insures there aren't any breaks in the heating element that you can't see. If there is continuity then you possible could have a hi limit switch (this looks like a small round button about the size of a dime, located in the housing holding your element) burnt out. If the element is burnt out there will be no continuity on the element. If there is continuity then take the hi lmit swithch out and replace it. Take the model and serial numbers to an appliance parts store for replacement. Good Luck
    Dave
    Jul 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
    Not heating properly, many cycles to dry loads
    Check the following to address this issue--
    Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
    1. Venting
    Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
    Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
    2. Thermostat
    There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
    3. Heating element
    A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
    Jun 02, 2009 | Maytag SDG3606A Gas Dryer
    MAYTAG DRYER
    If the heating element connections could be  loose or ithe element may have poor connection.  Check the voltage across the Line1 and Line2.  It should be 240V.  If it reads 110V then you will have very poor heating.  If the heating element is bad, it can be replaced.  Search for appliance parts vendors.
    Oct 16, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
    Dryers Logo
    167 people viewed this question
    Top Dryers Experts
    Marvin
    Marvin
