Motherboards
Generic problem for all Motherboards
Soltek motherboard boot problems
posted by 111059 on Jan 05, 2008
howdy I am having boot problems with the above board. the system boots then turns off then reboots. this can be at cmos level and or in windows. would it be the bios?
Comment posted on Jan 09, 2008
your suggestions for boot up where helpful, however the problem persists> i have replaced the cmos battery and reset configuration etc oddly enough the board is stable whilst in cmos settings panes.I suspect the capacitors on the board may be the trouble.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 06, 2008
Thanks for Trying (70)
Drooo
Rank:Master Master
Rating: 87%, 15 votes
Possibly. The machine may be overheating during the startup process. Also, if you are running an old version of windows. 98,95 upgrade and it should fix the problem. One more tip, go into your BIOS, by hitting the F1,F2 or Del or F10 key and then select and enter load failsafe settings. If you cant even get into the BIOS, check that the CPU fans are operational inside the case, if they arent replace them, if they are. Look for a small silver battery called the CMOS batterdy, take it out for about 5 minutes then put it back in and this should fix your problem.
Rating Locked! (?) 111059 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on soltek motherboard boot problems:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
Hi, I assembled a PC comprising of the following...
Motherboards
switching motherboards and the wiring isnt the same. i...
Motherboards
SiS 760 Display Adapter not functioning. I also have...
Jetway (V2MDMP) Motherboard
Good people out there. can you please give me a mobo...
Intel Motherboard
i have not audio and video
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
