Question about E-Machines T1360 PC Desktop
I don't know what this is
I took apart my old, broken t1360 and found the chip that has the two usb ports and a mike and speaker port.
This is from the front of the case, at the bottom.
I'm looking for a replacement that is exactly the same size, supports usb 2.0, and is compatable with most motherboards.
or if that doesn't exist, I'm just wondering who made this and if it will work on a new motherboard.
  • Chris Park
    Chris Park Jan 05, 2008
    Do they sell anything like this anywhere?
    Novelist:
    Scholar:
  • 136 Answers
Hi
It is possible that it will work on a new motherboard as long as the cables connects it to the motherboard matches. On your new mobo you should see pins for for usb and sound to plug to the mobo..most new cases have this though so you shouldnt really need it. However if you want to reuse your case to take advantage of the chip it should fit.
good luck
smeags
Posted on Jan 05, 2008
I have broken charger port on my JBL Pulse speaker! I was wondering if this is an easy fix..or if anyone knows how to safely take the speaker apart it would be most helpful!
The JBL Pulse 2 USB fails all the time. JBL makes warrantee work quite difficult to get. Heres how I fixed the USB port to charge my speaker.
1. Remove rubber ring on the bottom . Warm it up with a hair dryer or heat gun, its hot glued on.
2. Unscrew the four silver screws you find under the rubber, remove the vanity ring.
3. Unscrew the four black screws you rind under the vanity ring. Gently pry between the grate and this part and loosen this structural part. Its attached to the rubber strip that has all the buttons, so your just going to bend it back.
4, warm up the black diaphram with the JBL logo in the middle and peel it off carefully.. Again. hot glued.
5. Locate the plug in the middle (white) with one red and one black wire attached. Labeled "GND VUSB"
6. Remove that plug. (this is the charge power from the broken usb port)
7. Get a 'PH2' connector with pigtails from your buddy who flys drones. (or get one on amazon)
8. Drill a small hole at the base of the black USB/aux in plastic into the body of the speaker
9. Plug in the PH2 to the GND VUSB port, run the wires out the hole.
10. Sacrafice an old USB charging cord for a camera, or this speaker, cut it, expose the red and black wires. Solder red to red black to black. Cover solder joints with shrink tube.
11. Plug it in and see if it charges! if So.
12. Put the diaphram back on with hot glue, then step 3 and 2 in reverse, then make sure you figure out how to line up the black rubber ring before you stick it back on with hot glue. (Its got high and low spots. ask me how I know)
Jul 13, 2014 | Audio Players & Recorders
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
How to take apart
The port was broken on mine also. I looked online and found no help so I decided tear it apart since it was broken anyway. There are 6 phillips head screws located under the speaker cover. The black mesh material is glued down so you have to pry it up and then peel. The backing tore on mine so it will be a challenge to actually remove it without damaging it. Once it is off, you can remove the 6 screws and it will open right up. The charger port is located inside a small black box that is held down by 2 screws. Once I got to the little charging port, I found that it had become separated from the circuit board and couldn't be put back on. Not unless you know how to solder or do circuitry. I figure it isn't repairable.
Dec 27, 2012 | iHome iDM12 Rechargeable Portable...
Bad sound from laptop speaker
To change the speaker, you would have to take apart the whole laptop because top bezel wouuld need to come off. As far as replacing the broken LAN port, you would need the exact LAN port. Meaning you would need to unsolderr the old LAN port an replace it with the new working LAN port. Either way you would have to take the laptop apart and to take off the top bezel.
Apr 19, 2010 | IBM ThinkPad A21m 2628 Notebook
USB port on side of computer dislodged into computer.
Probably broken off the board, you will need to get this out as there's a possibility it could short out and fry the motherboard!
Apr 17, 2010 | Toshiba Satellite A75-S226 Notebook
How can I replace a bad (unuseable) USB port in a computer
More than likey the pins on the usb port have become loose.
You would need to take apart the laptop and either
A. re solder the pins
B. Replace the USB port
C. The motherboard is bad
Guide to disassemble your laptop
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
To solder you will need a soldering iron (perferably one with an adjustable wattage 40Watts should be good and some .2mm solder works good for computers since its very fine and easierto solder small contact points
Once the computer is apart locate the USB port and flip the motherboard over and there should be 4 pins, you should be able to wiggle them if they are loose
Apply solder to loose pin to secure it or form a big glob of solder on it and use a solder pump to pull off all the old solder and re solder, this is the preferred method because it ensure the entire pin is surrounded by new solder
For a Novice this will probably take around 3 hours
Nov 02, 2009 | HP Pavilion dv6000z Notebook
Right speakers don't work
After taking the unit apart, I found that the speaker wire had broken, at the point where it passes through the hinge. Although the wire is reinforced with plastic in this area, wiggling the wire showed that the break was there. I removed the coating and found that both wires were broken. That was it. No problem.
Aug 05, 2008 | Altec Lansing inMotion Plus Portable Audio...
F20 power port connection broken in unit.
I have recently acquired a Navman F20 Satnav with a broken USB port (It was rattling around inside the unit.)
I took apart the case and re-fitted the USB port with no problems at all. Just with a steady hand and a fine tipped soldering iron. I also superglued the port in place to add extra strength.
Put it all back together, and it now charges and connects to the PC exactly as it should.
So, before you throw away a sat nav with this problem, contact me and I can fix it for you, or, alternatively I will offer to buy the broken unit from you.
My Email address is darren.lee27@ntlworld.com.
Thanks
Jun 22, 2008 | Navman F20 GPS Receiver
I don't know the parts of the motherboard.
What motherboard would you like to know the layout of? Although, many motherboards are different, most of them have the same basic parts. From back to front, you have the communication ports; (usually from top to bottom, varies by manufacturer)mouse/keyboard, usb 1.0/1.1/2.0(make and model dependant) serial, paralell, vga/monitor, then sound: midi, headphone/speaker out, line out, microphone in.
then on the board, processor, somewhere near it, cache, i/o chip, north bride chip, wich is responsable for memory(ram) access, ide(cd rom/ hard drive access) ports and power connector/s,
memory slots
then the south bridge chip witch controls isa port(old), pci slot, agp/pci-e slot (video card) along with the cmos battery, bios, and various other slots/connectors (such as fan, power button and so on) and chips, wich vary by manufacturer and model.
Dec 27, 2007 | Computers & Internet
Laptop fell onto floor...now my memorex travel drive is broken...all college papers lost...help
This is actually fairly common, if the laptop still works with the broken USB socket you can take the cheap approach which is just don't use that port. If you need more ports a USB hub is pretty inexpensive.
Nov 27, 2007 | Electronics - Others
E-Machines T1360 PC Desktop Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
