Question about Olympus Stylus 770 SW Digital Camera
Waterproofing I have had the 770SW for 6 months now and it has performed well in water. I was wondering if it is a good idea to buy silcone grease from a dive shop to occasionally grease the O rings seals?
  • 667 Answers
It would be handy to have some, but you never need very much to keep seals pliable. Too much grease will attract debris the may cause your seals to fail. Clean the seals occasionally. As long as they are not damaged, your seals will likely outlast the camera.
Posted on Jan 05, 2008
Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Dec 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
Waterproof ? Only third time in water !
certainly if the camera is not working.........
some water might have swept in it........
there might not be any other except waiting for the water inside to dry out........
may be it will start working.....
otherwise u will have to tell te company,,,about this
Oct 04, 2008 | Olympus Stylus 770 SW Digital Camera
Tip
CPU Performance
For the best CPU Performance.
Its Recommend Replacing the thermal grease once every six months.This way the new grease will give to more kick out of your PC And you will notice the difference and performance .the old grease is warn out But can Still be use but it slows down your pc.
the makers of CPU's don't want you to know this because they want you to buy and upgrade to there new CPU all the time
(((I GOOD LUCK ENJOY A FASTER PC )))
on Aug 26, 2008 | Microsoft Windows XP Professional With...
Change water filter
You can check the local Home Depot or Lowes if you have one near by.
Both have a good selection of filters for refrigerators.
Another good online source can be found here.
Oct 18, 2009 | Whirlpool Refrigerators
On my 1983 Crown Vic, the water disappears and I'm not sure where its going. new water pump, thermostat, ran great for 6 months after these were installed. not leaking, radiator was flushed out, new oil...
There is a chance the water it' been burn by the car . It's posible that a internal leak between the Intake manifold gasket or the head gasket going thruogh the combustion chamber.
A good idea will be to perform a radiator pressure test to determine that, also you can have your sparkplugs inspected for signs of an abnormal condition, sometimes they can tell you a lot.
Sep 15, 2009 | 1983 Ford Crown Victoria
Engine runs, no pressure
Hello bsinger:
If it is not leaking water anywhere and the nozzle is OK then go HERE
Turn it off and shut the water of. Go to pate 2.1 of the manual
Carefully remove part #2. Pull out part # 1 and make sure the O-rings are in good shape ad are lubricated with a good waterproof grease. Re-assemble and try it.
Jun 28, 2009 | Karcher G3025OH Pressure Washer
IPhone case
An OEM in China called CNN.cn has made anodized iPhone’s OEM back case available as replacement parts. For $46.99 you will be able to replace the back case of your iPhone. It comes in black color and does not include the chrome Apple logo.
The back case replacement is not for the faint of heart, as it requires you to remove your current back case. It is not a simple clip and drop in cover case.
Thanks,
PREM
Mar 24, 2009 | Apple iPhone Smartphone
Cassette Deck emits high-pitched whine
I like Silcone grease for this kind of thing. It's sold at electric shops such as Maplin (UK).
Jan 07, 2009 | Audio Players & Recorders
Drowned waterproof camera !!??
I would take batteries out open camera the best you can and let it dry out for a week at least!! then replace battery and try again,Most times when it is fully dry the camera will start to work again! ! If that does not work I would contact the company! and even if the warranty is up they may still fix the problem for free or low cost!
Jan 04, 2009 | Olympus Cameras
Information
Hey bella143,
The length of the video you can record is not determined by the camera it is determined by the size of the memory card you use. This camera comes with a 512mb memory card, and this camera should be able to record about 45 minutes of video on a 1gb card which should be about 22 minutes of video on a 512mb card. This of course is assuming your memory card is empty. I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 08, 2008 | Olympus Stylus 770 SW Digital Camera
Olympus Stylus 770 SW Digital Camera Logo
64 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
