GE Spacemaker  Microwave Oven
GE Spacesaver over the range microwave oven
shared by 6 users
posted by velettag on Jan 05, 2008
My first GE spacesaver just like this one lasted for 17 years. I have had this one for 5 and it just stopped heating. It turns onlike normal but nothing every heats up or defrosts. Any suggestions?
velettag
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
Posted by sclieu on Feb 01, 2008
Ok, this is both a request for more information as well as some updates and information for others that are novice like me.
First, the findings... I took an ohmmeter and tested the magnetron by touching it's 2 connectors. This resulted in no resistance (expected). I then touched each of the connector to the housing...this resulted in no resistance (NOT expected). From reading online, I should have seen infinite resistance. Assuming I'm correct (please, please, please), I went to remove the magnetron. Now, I read that the GE magnetron is under warranty for like 8-10 years. Well, mine is made in Oct 2000, and so I believe it's still under warranty. However, I also read that they will only replace the magnetron by an authorized GE installer....soooo my question is if there is a way for me to get a free magnetron from GE being that it's still under warranty, BUT I did the uninstall myself? Can I pay a service guy to order it and give him my 'bad' one?
On to how it was done:
I had to unmount the XL1400 from the wall. To do this, there are 3 screws on top of the microwave that was screwed through my top cabinet. These are easily removable. Next, I had to figure out how it was still mounted to the wall. I read some posting that says that there is a U bracket on the lower back of the microwave connected to a J bracket, and was trying to wiggle it out but that was unsuccessful. The microwave seemed like it was still bolted on with something in the back, so I went online to search more on what was holding it on. Unfotunately, 1 minute later, the microwave fell, but fortunately it only fell a short distance to the stove and it was still connected to the wall so the fall was slowed down..the mounting brackets just bented.
I saw how it was connected. Basically there are about 3 notchlike things along the back bottom connecting it to the wall frame. To unlatch them, I should have lifted only the back of the microwave and not the front and back (hard to do with a stove in your way and top cabitnet didn't give much room either to lift up). In any case, it's out.
I then had to remove the front control panel (a bunch of screws here and there), disconnect the connectors. Ddon't forget to discharge the HV Capacitor (I left mine unplugged for like 45 minutes as well since I was a bit nervous, and then touched the 2 terminals on the capacitor). Unfortunately, I still could not get to where I needed to go...the magnetron.
Next, I removed the fan housing...a few screws...wiggle out. Behind it finally, was a huge transformer and the 'magical' magnetron. My next hurdle was to unscrew the magnetron.
Well, this was harder than I thought. There's only 4 screws on top holding it on, but to get to the screws, I had to remove the outside housing (easy, just look for the screws along it's side). I thought I could get to it by removing the panel where one of the fuse was connected to (which was above the control panel on the inside) but that was fruitless. It only gave me a peak into the area, but no access. I had to remove the housing.
Finally, I was able to unscrew the magnetron...Finished? NO! Because the transformer was below the magnetron, I did not have enough clearance to get that damn magnetron out because of it's antennae. Next, I had to remove more screws so that I could lower the transformer. A few in the front, back, and sides. This allowed me to loosen the flooring that was bolted to the transformer, and finally, I got the magnetron out. I did this because I could not reach the 4 screws that were holding the transformer in it's place.
In any case, I know I must have done at least 10 things wrong, and probably did everything the long way, but at least I figured it out. Hopefully, someone can take this post and learn from it.
If anyone has any ideas about getting my warrantied magnetron, please let me know ASAP! My microwave is all over my kitchen table.
BTW, if you would like to see any pictures of the gutted beast, let me know. I will have it open until I figured where and how to get my magnetron (hopefully for free) ...at least a day or 2.
Thanks
Posted by sclieu on Jan 25, 2008
Regarding the bad solder connections, would this be an obvious visual inspection for any disconnected/loose wires? If none, then replacing the magnetron would be the next bet?
Any ideas of how difficult to do either? I found a web site for the magnetron part, and it was around $130. Is this reasonable?
Thanks!
5 Other Users Have The Same Problem
Posted by HollyBuddy on Feb 01, 2008
Same here. It happened one time before too, and after a day or two and multiple attempts, it started working again. This time it pooped out last night. Everything else works but no heat. We just had a huge windstorm here, not sure if that has something to do with it?
Same here! Started failing yesterday morning, and no longer heats since. Weird that a lot of folks are seeing this problem at around the same time. Wonder if it's a HW/SW virus set to go off a certain number of years after manufacturing date.
Posted by Faithsoars on Jan 08, 2008
Exact same problem. Last night it worked, this morning everything seems to be working but nothing heats. Is it something about January? I see all the posts were made this month. We've been in our home two years, and before that, it was the model home so it's really only had two years of service.
Posted by signgirl01 on Jan 06, 2008
Same exact problem here! Our model is the XL1400 - has probably been used for 7 years (we've only been in this house for 1). Please help - we'd much rather find a cost effective solution than have it end up in a landfill!
Thanks!
Posted by SamHastings on Jan 05, 2008
Same as previous post. Looks like it is working, but nothing happens. Lights, camera, but no action.
Best Solution
posted on Jan 25, 2008
Helpful (85)
Totalwreck
Rank:Wiz Wiz
Rating: 86%, 42 votes
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Comment posted on Jan 26, 2008
The Power Relay Board is a printed circuit board of medium size. You can find it by following the two wires on the LV side of the HV Power Transformer back to the board.
To test: connect a Volt-Ohm Meter to the LV side of the HV Transformer (this will be the same two wires to the board). Set your Meter above 120Volt AC setting. Put a load inside the MW Oven say a cup of water. Plug Mw in and turn on. The meter should read 120 Volts if the board connections are good. If no Voltage, connections on board are open. Can sometimes be seen as burned on solder side of board. Clean connections and re-solder solid. If you have 120Volts at the LV side of the HV Transformer---Then you have a High Voltage Side Problem. Mag, Hv Diode, Capacitor.
Good Luck
Comment posted on Feb 02, 2008
To sclieu. The Magnetron should have a reading of 1ohm between the two terminals. This is reading the filiament. If you get no reading between the two terminals, ..Then your filiament is OPEN. NO Filiament = No Output.
There should be NO continuity (ohms) between the Magnetron case (frame, Ground) and the Magnetron Terminals. Continuity = SHORT.
You stated (in your latest post)" I took an ohmeter and tested the Magnetron by touching it's 2 connectors. The result is no resistance (expected)". The Magnetron SHOULD HAVE A 1ohm READING between the 2 terminals. This is the Filiament.
Now that the Magnetron has been removed Re-Test it with your Ohmeter.
To sclieu. If you get no resistance reading between the 2 Magnetron terminals, then the Filiament is OPEN. There should be a 1ohm reading between the terminals. OPEN Filiament = NO OUTPUT. Open Filiament. Replace Magnetron!!
Re-Test your Magnetron with the Ohmmeter. To be sure.
There should be NO resistance, or infinity, between Magnetron terminals and the Magnetron case (frame, ground). Any Resistance Reading would indicate SHORT.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on GE Spacesaver over the range microwave oven:
I don't want to Accept this solution
Solution #2
posted on Jan 06, 2008
Thanks for Trying (70)
vettesrbadas
Rank:Master Master
Rating: 79%, 15 votes
94% of the problems with ALL microwaves is the magnatron. i guarantee it!!!!
Thank You!
Solution #3
posted on Feb 17, 2008
Not Rated (0)
sclieu
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Update: I ordered a magetron from someone with an ebay store for about $43 with shipping already included (was a part from a display model but with moneyback guarantee). I installed it and microwave works! Thanks, Totalwreck for saving me hundreds of dollars!
Thank You!
Can you Help with these Microwave Ovens problems?
GE Spacemaker (JVM1640SJ) Microwave Oven
GE spacemaker XL1800 Mircowave will not heat, Everything...
GE Microwave is not working. I can't even set the clock.
everything else seems to work. unit has been used 6 years...
Hello I have a GE spacesaver microwave oven serial #...
The light comes on inside but when you try to start by...
Loading problems.
Repair Service
Find Microwave Oven Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
