Question about Equipex PZ-330 Electric Single Oven
Broiling do you leave the oven door half open or closed when broiling
Broiling in a recently manufactured electric oven is practically impossible, because the heat element turns itself off. So you must close the door and end up baking, In despair, I now broil meat in a small toaster oven that leaves the Infrared heating element on when the door is cracked open. The meat tastes much better than it does when cooked in my fancy wall oven. The only alternatives that are to use a gas oven or to barbecue the meat. It is very clear to me that electric oven designers and engineers, (especially for the fancier ones) never cook themselves. They probably can afford to go into expensive restaurants, where the French chef cooks meat with an open-door oven or a grill. :-(
Posted on Sep 23, 2013
  • 640 Answers
It really doesnt matter because the heat transfers directly onto the food therefore you can leave the door open or shut.
Posted on Jan 05, 2008
Unit shuts off when using broiler
can't broil with door open with these models. If closed, most likely an air flow issue with the cooling fan above in the control panel.
Nov 15, 2013 | Thermador C272 Electric Double Oven
Closed door, pushed clean button, but door lock button keeps flashing and door won't lock.
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Sep 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
Do I leave the oven door open a little while broiling?
Yes, it is a good idea to let it open just in the first posistion which gives it about a 3 or 4 inch opening at the top. This will hold enough heat in to broil your food but will let enough out so that the ovenwill not over heat and it will keep the burner on. Usually broiling times are not that long so this will not over heat your home or present any other dangers. Of course you still want to preheat the oven with the door cloded for best results.
Jan 28, 2010 | Kenmore Ovens
Removing oven door
Usually you open the door to spot where you leave it for broil. It should sort of stay in that position. Then just lift it out at that same angle.
Dec 01, 2009 | Whirlpool Ovens
Oven door won't close fully.
The only satisfactory solution, is to replace both the oven door hinges,\ which is a fairly straightforward job to do.
Please rate my solution.
Nov 09, 2009 | Bosch Ovens
Element Question
In most ovens, both elements are used during the warmup phase even when used for baking and after the set-temperature is reached, the lower element keeps it stable.
You should be able to detect which one is not working with your bare hand. Set the baking temperature for 250-300 degrees, leaving the oven door open. Hold your hand at different heights in the oven and you should be able to sense which element is working and which isn't within a couple of minutes.
If you still aren't certain, then try using the broil element only. If it is heating, then it's obviously OK and that would point to the bake (lower) element by default.
A final check could be done with an open door and hovering with your hand over the lower element; no heat = defective.
Mar 03, 2009 | Amana AOES3030SS Oven
Frigidaire gallery self cleaning convection oven
Press and hold the "clean" button for 5 seconds.
May 11, 2008 | Ovens
Frigidaire single oven broiling
The pan and it's grid is all you need, The broiler pan and it grid allow dripping grease to drain and be kept away from the high heat of the broiler. DO NOT use the pan without its grid. DO NOT cover the grid with foil. Some helpful info.. Preheating is suggested when searing rare steaks. Broil on side until the food is browned; turn and cook on the second side. Broiling times vary, so watch the food closely. Time not only depends on the distance from element, but on the thickness and aging of meat, fat content and doneness preferred. The first side usually requires a few minutes longer than second. BE SURE THE DOOR IS OPEN AN INCH OR TWO WHILE BROILING
Mar 21, 2008 | Frigidaire FEB24S2AB Single Oven
Kemore oven door signal
The door switch is faulty or not closing.Without the model the switch may be in different places.where the door closes check to see if theres a button if there is thats the switch.regardless look around the seal of where the door shuts for the switch.When you do find it simply disconnect the wires from the switch (there should be 2) and put them together.this should solve your issue.
Feb 23, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Equipex PZ-330 Electric Single Oven Logo
163 people viewed this question
Top Equipex Ovens Experts
Dan Webster
Dan Webster
Are you an Equipex Oven Expert? Answer questions, earn points and help others
