Question about Sony PlayStation 2 (PS2) Console
Ps2 error my ps2 will play most all games, but i  just bought a new one and it is blue on one side. this disc will not read.
  • Heffdaddy Jan 08, 2008
    Nerd boy at Gamestop says to change the disc speed. Duh I have
    been into the configuration setup and nothing I see there will adjust
    the speed in which the disc turns. Any bright ideas before I take
    the PS2 out for some target practice? Thanks!! This is
    concerning the blue discs only.
  • 709 Answers
See if you can play an Audio CD. if you cannot then your Laser CD reading circuit is out of adjustment. Clean the lens and try and if that doesnt work, Add refridgerator magnet to the white clamp that hold the Disc on the Drive spindle. Use a Maghifying glas to get a close look at your Laser lens, and clean off any lint or smudges.
Posted on Jan 07, 2008
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 31 Answers
SOURCE: ps2 disc read error
This is a common problem with the PS2 - the laser head is out of alignment.
This is not a problem that a novice should try to fix. In most cases I your best solution is to take the PS2 to a local repair shop - many TV repair shops also repair PS2's, and this is a very common problem that they will be aware of and familiar with.
The upside of taking it to the repair shop is that they will give a limited warranty on the repair so that if the problem pops up again (that happens often too) you can take it back and have them fix it again for free. The downside is that many shops charge you more to repair this than it would cost to purchase a used and working unit on EBay...
If you feel confident in your ability to do the repair yourself, please consult this website for step by step instructions:
http://arstechnica.com/articles/paedia/hardware/ps2.ars
The instructions on this site are excellent - I have used this tutorial myself to correct this problem on PS2's. One small point that I want to add - you will be adjusting the height of a laser. Do NOT look into the laser with it turned on! Be sure to place the laser cover back in its slot prior to turning the unit on to test it.
Posted on Nov 15, 2007
MrARCADIAN
Arcadian Duran
  • 284 Answers
SOURCE: disc read error
get it repaired. obviously the drive is not spinning correctly for ps2 disc. so take it to a shop ask for a quote to repair.
most ps2 are about $99.00USD
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Jun 11, 2008
Anonymous
  • 10 Answers
SOURCE: Rockband PS2 brand new disc will not read
This usually happens when the lens eye is dirty, to clean use a Q-tip with some rubbing alcohol on it. the disk tray should be cleaned also. use the other end of the Q-tip to dry the access rubbing alcohol. Also you can use compressed air in a can to blow dirt and dust out. Hope this solution help your problem.
Posted on Feb 18, 2009
Anonymous
  • 32 Answers
SOURCE: PS2 will play any audio cd and any ps2 blue game
sounds like your laser is failing. You can find tutorials on how to adjust, clean or replace your laser. Do a google search for " ps22_bing.gif disc read error " it will give you a choice of plenty of tutorials to follow. Good luck
Posted on Feb 05, 2010
PS2 will play any audio cd and any ps2 blue game disc. but it will not entertain a silver game disc or dvd. just keep getting Disc read error.
Feb 04, 2010 | Sony PlayStation 2 (PS2) Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Wont load
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
If your PS2 can not play certain games like Rock band try this tip:
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  5. New screen will appear like
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
And after that wait till your game is loaded.
Click here to view full tip.
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 makes a clicking sound and gives "disc could not be read"
I had the same problem with mine. it would play the ps2 games just fine but when i put a DVD in, it would click and keep saying reading disc.. i took it apart and gently cleaned the lense with a qtip and now it works fine
Aug 21, 2009 | Sony PlayStation 2 (PS2) Console
Will not read blue discs no problem with clear(silver) ones tho.
1. Apparently, blue PS2 discs are lighter than silver ones, so they tend to move around more when the PS2 is reading them. To fix this, you can put duct tape on the top of the disc. This will make it heavier, so it won't move around too much and it should make reading the disc easier for your poor PS2. People have told me that this indeed works (but not always). Don't go overboard with the tape though. Attempt at your own risk. 2. If the problems occurs when the PS2 is horizontal, try putting it into its vertical position. Or try putting it horizontal if it is vertical. 3. Use a can of compressed air to clean dust out of the system. 4. Make sure your game discs are not the problem. Keep them as clean as possible. Even small scratches can cause problems. 5. Open up your PS2 and clean it out or try adjusting the lens. Very risky and voids your warranty. 6. Try using a DVD lens cleaner (for problems reading silver discs) or a CD lens cleaner (for blue disc problems). 7. Send your system to Sony for repairs. Due to a lawsuit, Sony may have to repair your PS2 for free even if there is no warranty. Contact Sony for details. That is all the advice I can give. If the len(s) cleaners or compressed air don't work, then you are probably just out of luck. There is no magic way to suddenly get your PS2 working again without professional repair.
The trick to getting the discs to play on any [email protected] (old or new) when they are black or blue is to put a piece of tape lengthwise and width wise around the hole in the disc on the topside (picture-side) of the disc. What this does is add weight to the disc and thus allows the PS2 to read it more accurately. I had bought many older titles not too long ago and was disappointed when they didn't work. Then I spoke with a Japanese expert online and he suggested using scotch tape around the hole in the disc and it worked instantly. Don't be fooled into buying a new PS2, just a roll of scotch tape. You'll only need four one inch strips.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 wont read discs and asks for format disc
I can guess that the games you are trying to play have a Blue underneath and not silver. This was a big problem with my sons disks too using the older version of the ps2. We managed to mess about with some of the settings and changed the rgb setting to the other option (can't remember what that was now...sorry) and got some of them to work, but not for long. When the new games come out now they expect you to have the slimline ps2 and unfortunalty won't work on the older model. So to fix this problem I just bought a new one.
Oct 26, 2008 | Sony PlayStation 2 (PS2) Console
My PS2 plays every discs except blue discs
Take a lens cleaner disk, and then run it three times. The ps2 will work or if it doesn't. Its time to upgrade to slimline.
Jul 06, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Jun 07, 2008 | Sony PlayStation 2 (PS2) Console
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Slim ps2
disc not scratched? laser maybe dying! how did you clean the laser?
Oct 13, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
