Question about Samsung RS2630SH Side by Side Refrigerator
Water comes out very slow
Can you help
Your filter might be clogged. You can only buy a small original Samsung filter for $45 and it will clog in six months or less.
The other option is the cooling tank for water is freezing in your refrigerator section.
Mine is doing that now.
Posted on Jan 11, 2008
Our water is coming out very slow. Please help!
Have you changed the filter?
When water filter gets old and clogged with debris it slows the water output.
Our side by side different brand's filter is on the bottom front by the grill looks like a round dial to turn and pull out.
Dec 19, 2010 | Roper RS25AEXLQ Side by Side Refrigerator
Can water flow be adjusted water comes out very slow
Yes, providing the water filter has been changed regulary. That would be number one reason for water slowing down. If you hae done that we will work with supply, Sea Breeze
May 19, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Water going into machine slow, water coming from
there will be either 2 or 3 screws on the rear of the lid,remove and slide the lid backwards, lifting slightly on some models.
Oct 04, 2009 | Washing Machines
Water in door too slow coming out
A strainer before the inlet valve can get stopped up restricting flow. It's on the back where the water supply connects.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 20, 2009 | Refrigerators
Why would the water start coming out very slow?
If you are referring to water coming out the fountain it could be a leak in the system somewhere allowing air into the lines that run the water, if you are referring to water coming out of the ice maker itself you need a new ice maker the lining is bad
Jul 14, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Cold water will come in verry slow
if your water pressure is good the water valves are bad.
Dec 14, 2008 | Washing Machines
Water in refrigerator door coming out slow
Hi Ben22 Sounds like some thing pluging the water line or the water line pinched some where.. if the hole was 1/4 inch you should get enough water with that big of a hole. I would check the water line for a obstruction. Let me know if this helps. Krazytech
Sep 29, 2007 | Whirlpool ED5SHAXM Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
149 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
