I have loved this receiver, but the receiver nows shuts off when watching a movie and there are some deep bass tones in the movie. I can then turn on the receiver again, lower the volume and usually are ok. Any idea what could be causing this?
My email address is [email protected]
Thank you for your assistance
I own a Yamaha RX-V795a, and it's worked great for the past 8 years, but recently it's having problems. I can watch a movie greater than 1/4 volume and in no specific time frame it will turn off. I can turn it back on and it will do the same thing right away, but when i decrease the volume it will work fine. I havn't changed any wiring or anything for past few years, and it just started doing this about 4-5 months ago. It there a resistor that is overloading that needs replaced or is it a bigger issue. Is the repair going to be worth it versus buying a new one? Please let me know if it is an easy fix. Any advise is helpfull. Thanks
Those recivers are usually preety good oones with little to no problems. Its just when it gets a certin age it extends its life. You can take it in to a technician to have it serviced, mostly you have cracked solders on the board which will accout for the problems you are having. there might be a few things that need changing but basically your recuver is good it just needs servicing thats all.
Or if you prefer you could get a new one.. BUT YOU CAN JUST HAVE THE CURRENT ONE YOU GOT SERVICED..
a service wil include
re-soldering cracked or loose solders on the board
changing a couple of stuff, maybe capicators or resistors and unlikely an ic.
dusting it
So just take it in to a technician for a service cause its reached it life span ,,
About how much should a service like that range.
Thanks for your help
