Question about Toshiba Satellite M40-S417TD Notebook
Toshiba M40 could not be turnd on
Power supply is o.k, but the notebook is not turned on, no any lights, could be motherboard problem, could it be repared? or have to change new motherboard, and where can I got to get it? thanks
  • 4 more comments
  • Deef Jan 05, 2008
    I have tried the same way before, no lights on, nothing happen.
  • oldswabbie Jan 26, 2008
    Nothing on internal or external screen. Removing battery doesn't help.
    Pushing power button does not turn off but holding it continuously recycles on/off but still nothing to internal or external screen...
    System won't start.....
    Has only one memory chip, a 512meg chip...could it be bad?
  • Labrador72 Apr 01, 2008
    I have just had the same problem with my M40: for a couple of weeks Windows wouldn't switch off and had to push the power button or even remove the battery and disconnect the power cord to switch it off.
    Then all of a sudden it went dead and there is no power, all the leds are off.
    I tried to remove the battery and and use only the power adapter but still dead. The power adapter is working because, when connected, it slightly warms up.
    I have been told by support that it probably is the motherboard which would cost at least €300 to be fixed. If I have to spend that sum to fix a nearly 3-year-old laptop, I might as well spend twice as much and get a brand new one!
    Could there be any other reason? Is there way way I can figure out myself what the actual problem is?
  • krecidy Jul 03, 2008
    I have a M40X toshiba, sometimes on start up,just after the toshiba logo, the screen goes very dim, I can see icons if you hold a strong light at an angle, it is an intermittent problem, I have replaced the inverter but made no difference, checked wiring and moved/shaken but screen will not come on when dim and will not go dim if the screen is normal-bright, so does not seem like a lose connection, has any one go an suggestions?
  • Anonymous Dec 11, 2008
    toshiba m40 -jm8 ligts are blue,when cord is plugged in,all other things don't work.It can not start.
  • Jason_Tweddl Jan 15, 2009
    Same problem here, battery or no battery, lights on front of laptop light up when plugged in but when turning it on, the blue power turn on light just comes on with the fan and disk drive for approx. 3 secs then it shuts off again. Any suggestions?
  • 233 Answers
Take battery out, plug in and turn on. does it turn on? any lights on the laptop on?
Posted on Jan 05, 2008
I have a brand new power supply for the unit but system won't turn on
might sound silly,but have you turnd on the power switch for the pc if it has one,and the one on your power supply,
if you have check the fuse in the power supply,or check the fuse in your main power lead.
Mar 29, 2015 | Computers & Internet
My westinghouse 46" led tv will not turn on, tested the ac power supply and its good
The problem might be of its mother board itself. Contact any experienced service technician to make it confirm before change it. There are so many adjustments should be done after changing a new mother board. It is not a user reparable work.
Jan 16, 2013 | Westinghouse Televison & Video
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
I have a toshiba satellite pro 4600 - no power at the display or lights - the power supply is working?
yes youre right, the power supply or the motherboard is not working. You can try to press and hold the power button for 8 secs to turn it on. If it is still did not work, call toshiba for possible power supply or motherboard laptop repair...
Nov 12, 2010 | Toshiba Satellite Pro 4600 Notebook
My Dell xps m1330 won't power on , the light on the power supply is on until I plug it into the laptop an try to turn it on, then the power supply light goes out.
try removing the battery, plug the ac adapter, check if it turns on. if not it may be the ac adapter/motherboard might be bad.
Feb 14, 2010 | Dell XPS M1330 Notebook
I have a toshiba satellite A135-S4677 it doesnt start at all i have it plug in and no light from the laptop just the light from the power cord please help
the adaptor may be out it may not be supplying power to the laptop power supply circuit
or
the power unit circuit in the notebook may be out
or
the motherboard may be down...
only tech shop can fix it...
Jan 21, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite m40-244 no boot
Open the Notebook, and remove the System RAM slowly and clean it legs with a white paper and place it again and check,if the problem still persists insert the RAM in different Slot.
This will solve your problem.
Jan 02, 2010 | Computers & Internet
Presario sr1130nx desktop, lost power, won't start up now
there is problem with u'r SMPS. repare it or change a new one
Nov 03, 2009 | HP Remanufactured Compaq Presario SR1130NX...
New battery was fully charge but not working
M35x's had a massive recall regarding the motherboard and battery. unfortunately it sounds like your motherboard is failing
Oct 17, 2009 | Toshiba Satellite M35X-S149 Notebook
A200-1V0 power light and battery are on, but will not boot
try a new power supply if still same result problably you need new motherboard
Oct 13, 2009 | Computers & Internet
Toshiba Satellite M40-S417TD Notebook Logo
290 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
