Hello. Check out your reset button located on the top of the power nozzle. It is either black or red. Turn the cleaner on, and while running, push in the reset. Voila! It should be working again. The reset is put in the vac to protect your power nozzle motor. You have a geared belt that is driven by a circuit breaker protected motor. This way, if there is an overload on it, it will shut off, allowing you to clear it and reset it. I hope this helps! Have a good day.
Comments:
Nov 06, 2009
- You asked for help. If your power nozzle suddenly stopped working, that solution makes good sense. When someone tries to help you, you should have some manners, and if you already tried the circuit breaker with the machine running and I did not somehow magically read your mind then maybe I am the moron (by the way, check your ironic spelling). Good luck with your Electrolux, it is a fine machine. I am sorry that I couldn't help you. I am an EXPERT Electrolux tech. For ten years, I was a regional service manager for them.
my electrolux ultralux 2000 was shutting off after using for 10 min then retarting? I thought maybe...
(More)
my electrolux ultralux 2000 was shutting off after using for 10 min then retarting? I thought maybe that it was over heating due to dust/dirt. I took apart blew the dust out put back together but now it does not turn on? I might have crossed wires? Can anybody help me get it back together correctly
Hello! I have an Electrolux Ultralux 2000, w/power nozzle Model N1150. While using it today, it...
(More)
Hello! I have an Electrolux Ultralux 2000, w/power nozzle Model N1150. While using it today, it apparently "choked" on a dolls hair in my daughters room. I removed the hair and checked for any blockage, and there is none. Now, the brush simply won't turn. I have pushed the reset button (ours is a switch) but still nothing. Any ideas??? Thanks!!
how can i put on the snap ring on an eloctolux vacuum hose on the end piece of the hose; it is a...
(More)
how can i put on the snap ring on an eloctolux vacuum hose on the end piece of the hose; it is a swivel end and an older vacuum cleaner plastic canister type
I have an electrolux ultralux 80th anniversary edition that was over heating and shutting down. I...
(More)
I have an electrolux ultralux 80th anniversary edition that was over heating and shutting down. I took apart and blew out the dust now when I put it together it does not come on. I may have reconnected the wires wrong and do not have the manual. Where can Im get a manual?
