Question about Jensen JS1000-A Subwoofer
Subwoofer just stopped working. There's power but no sound.
I have a Jensen JS1000 Subwoofer. It was working fine for New Year's Eve and then the next day it wouldn't work. We use this subwoofer on a daily basis and never had a problem. The LED still turns on but there's no sound. Not even the slightest noise or vibration. I checked The Power plug, the phono plugs, and even opened up the back.There's no burning smell. nothing seems fried. The wires are all connected. The Speaker isn't damaged. I checked the fuse, it was fine but I still replaced it. Still no sound. Please help if you have any idea what this problem may be.
  • 4 more comments
  • batchy Jan 13, 2008
    diddo, exact problem as you with an Acoustics Precision sub. I haven't found the problem yet either. I also took mine apart. Speaker works, so it is in the circuit board somewhere...........?????
  • flaco23 Feb 01, 2008
    Same here, my Pioneer sub is doing the same. It was working fine, I didn't use it for a while and now it won't work. It turns on but no sound,I'llget a thump when i turn it on but thats it.
  • scottydog1 Apr 23, 2008
    I have a 10'' Precision Acoustics sub.Last night while going to bed I heard a loud hum and vibration. I went downstairs,the stereo was off but the sub was humming loudly.I unplugged the sub disconnected it and brought it upstairs.I checked the fuse,fine.I plugged it into the wall away from any electronics and I get the same loud hum.Is it Blown?.What would cause a sub to go when the amp is off.
  • Anonymous Mar 16, 2009
    i have Labtec pulse 485 but for some reason the satellites work but no bass, it has been working for more than 3 years so whats wrong now?
  • Anonymous May 18, 2009
    my sub blew up too this is the second time
  • Anonymous Mar 12, 2014
    I plugged the sound connectors and the humming noise doesn't go away, no sound comes from the subwoofer.
If thres a sticking sound when u press down on the sub or a wierd noise the sub is BLOWN
Posted on Sep 15, 2008
I have the same problem. My guess is that the subwoofer coil is messed up. You MIGHT have to get it recoiled. But before you do any of that get someone with a sub to play their sub in your car, if it works.... then your sub is messed up, if not.....then your amp is messed up ( trial and error ). Today i noticed my subs rubber surrounding is crooked, that may be the problem for me. Also when I press down on the sub it makes a sticking sound, like something came loose. So once i get everything opened and out ill let you all know the solution. Good Luck!
Posted on Apr 10, 2008
Why is my Jensen SPX-17 home entertainment subwoofer only putting out about 10% functioning base power volume level and loudness?
Gary, If you have the subwoofer open, what did you keep from measuring the voltage of both power supplies? And while measuring, why not put a load on both, and see what current they can handle?
When the error moves with one component (power supply) the error must be there. Without a multimeter, (I have several, but I'm not close to the power supplies) you can't tell if the power supply is working to full performance. So start there.
Just try to find out, if a part of the rectifier is defect (one diode) It won't be possible to point out what is wrong, if you can't measure on the device yourself.
Sorry.
Nov 23, 2014 | Audio Players & Recorders
No sound fuse good lite comes on
Chances are the main output semi-conductor has failed. It will be largest of the parts and might be on a heatsink. If it is an IC, 9 times out of 10, I would say it's gone.
Mar 31, 2010 | Jensen JS1000-A Subwoofer
Jensen JPS12 growls at random...
Get rid of it and get a real sub!
Sep 27, 2009 | Jensen JPS12 Subwoofer
JS 1000
audiovox ownes jensen so you might try this site, but no js 1000 models are shown, however, jps 8"/10"/12" are and you can download pdf manuals. one may be comparable to yours. or you can contact their customer service and they may be able to help further.
http://www.audiovox.com/webapp/wcs/stores/servlet/GenProductListCmd?categoryId=5025&type=prev&langId=-1&storeId=10001&catalogId=10001
sorry not a better solution.
Oct 02, 2008 | Jensen JS1000-A Subwoofer
Farting Noise
Do a more detailed search there is a solution but you will have to send it out to get repaired the noise is from when it goes on stand by...jensen is of no help
Aug 27, 2007 | Jensen JPS10 Subwoofer
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Jensen JS1000-A sub stopped working, why?
Is is possible that the receiver's subwoofer configuration turned off? double check your speakers setup in the receiver...Just an idea.
Jun 30, 2007 | Jensen JS1000-A Subwoofer
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
Jensen JS1000-A Subwoofer Logo
4,043 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
