1997 BMW 328 Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1997 bmw 328i not starting
Hi, i left my 1998 bmw 328i parked for quite some time, eventually i got around to starting it, suddenly after 20mins the car shut down and never started since, ive tryed everything. can it be the key programme/ ecu.
Anonymous
Level 2:
  • Expert 437 Answers
  • Posted on Nov 05, 2009
Anonymous
Expert
Level 2:
Answers
437
Questions
0
Helped
131000
Points
562
Come on give us more information. Think if you were trying to fix your own problem and you had to explain the problem to someone else with exactly no knowledge of what's going on.
1st off....a key with bad electronics and reader will open the door and that's it.
So that being said does the key turn the engine? If so the key, the program and ecu are ok. Say the engine cranks but doesn't start. Fuel pump. unscrew the access plug on the fuel rail and see if any fuel squirts out. NO......don't ever do this when it's hot..........not that yours is because it doesn't run but I had to say that. The millisecond you turn your key over to get it to try to start...the fuel pump comes on and pressurizes the entire fuel system.
Got fuel pressure, the engine turns but still no start= ignition spark plug engine computer problems.
  • Anonymous Nov 02, 2011
    after i parked my bmw 328i 1998 for a bit,, it starts up but idles off... what could be the cause ? it will run as long as i keep my foot on the accelerator
1helpful
1998 bmw 328i input time light is on
You need to set the clock. Press and hold the "Clock" button then use the 1,10,100,1000 buttons to change the time. When you're done press the "set" button.
These instructions are for a 93 but the process should be similar for your version.
1helpful
1997 bmw 328i dash lights all lit up at once and after several minutes they faded, and eventually the headlights and dashboard lights dimmed.
Alternator. Have it tested with a voltmeter while on the car and running. Or take it off and have it tested. The current to run the car and the accessories is from the alternator when the engine is running. The battery light coming on alerts you that the alternator is not doing its job.
2answers
1997 BMW 328i convertible automatic tranny slipping
to check oil start vehicle in park and let idle, open large allen bolt [normally 17mm] on g/box sump, oil should spill from aperture. if not top up until it does. this must be done at a temperature of less than 30 degrees celsius as oil expands at higher temperatures.
7helpful
2answers
2000 BMW 328i fusebox diagram
I have 1998 BMW 328i and it shut off entire air condition system while running. sometime it works fine then suddenly it shut off while driving.
My 1997 bmw 328i wont star after I replace the battery
I can't quite follow your post, but it sounds like you set off the car alarm. Lock and unlock your doors with the key Fob to reset it.
I've replaced the battery several times in my 328 without such a problem.
7helpful
2answers
1998 BMW 328i WARNING LIGHT IN THE DASH BOARD
Need to replace your brake pads.
Indicator light for a 1997 bmw 328i
i think it means that you have a turn signal bulb that needs replacing cause its not working. check turn signals and see if they are blinking properly from front & rear of vehicle.
1helpful
1998 328i Clock/Date Stopped Working
HI,
Please take a good look at the display, it may work.
Often there's only yhe backlight of the display which doesn't work.
You only have to replace some small lamps behind the display module.
Kind regards,
Gerard
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
