Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore 106.53603202 stopped cooling making a clicking sound
My rerfigarator a month ago stopped making ice and last night stopped cooling in the fridg and freezer. All lights and fans are working. There is a clicking noise about every 3 to 5 min comming from the back. Any Ideas sears can't get here until next week.
  • 4 more comments
  • cupracer20 Jan 05, 2008
    I want to thank you with the awsome quick respons. I pulled it off and it sounded like it was full of pepples. I will get a new one tomorrow and let you know if it did the trick it sounds like you know what your talking about I realy appreciate the help.
    Tony
    Jacksonville fl
    ok I put a new relay on and a new problem has came up the middle of the fridge is really warm almost hot to the touch as well as the compressor is this normal???
  • montab2000 Jan 08, 2008
    i am having the same problem as cupracer20's. we have a kenmore side by side model 106.5362300 it isnt staying cold and it clicks every few minutes. if it is the compressor relay, would our model have the compacitor? it sounds pretty simple to fix but wanted to make sure. i cant seem to find a diagram of our model or any other model. can you please help? thank you
    monta butler
    kenmore 106.53632300
    my freezer is intermittently not working and it keeps clicking on for 10 seconds every 5 minutes or so. the people at the parts house show a start relay or a overload piece, do i need any special tools such as an ohm resistor to change either part?
    Thanks
  • siestaguy Jan 09, 2009
    I have the same problem with the clicking sound too. I shook the compressor and it started working for a few hours but is now clicking again. I am really disappointed in Sears because this refrigerator isn't even 5 years old.
  • Anonymous Mar 22, 2014
    build up of ice on ceiling of freezer makes the temperatures go up and down and the fridge stop cooling for 3 days
  • 447 Answers
The compressor may not have to be changed it could be the relay that is bad, not properly starting the compressor. The relay is attached to the compressor where the wires go to it. Remove it, Shake it, If it sounds like little rocks are inside (it rattles) than it is bad. Let me know what you find
Posted on Jan 05, 2008
    Sergeant:
  • 288 Answers
The compressor is locked up. The clicking noise is the thermal overload turning the relay off and on. The only solutions you have are installing a hard start capacitor. Ther local appliance parts supplier will have this. Its easy to install I personally have had a 50% success rate with these, but its relatively cheap fix if it works, as the other solution is a new compressor. Good luck.
  • 290 Answers
It sounds like you have a burned out start relay on the compressor.
Pull the fridge out and remove the cover at the back. You will see the compressor. The relay plugs onto the compressor and the wires plug on to the relay.
Either the relay is burned out or the compressor is locked up. The only way to know for certain is to replace the relay. The relay is the problem on your model about 98% of the time. You can get one from any Whirlpool parts dealer for around $40, it will cost you around $280 for sears to replace it. The part number is 8201786.
Be sure you replace it with the correct replacement part, a fit-all or 3-in-1 start relay will work for a while but will damage your compressor over time.
Post back if you have any questions.
Mike
  • 1 more comment
  • Michael  Lindley
    Michael Lindley Jan 05, 2008
    Glad to be of help.
    The icemaker not working is going to be a seperate problem.
    Assuming you have a good water supply and your filter is not clogged, the most common part to fail is the motor module in the icemaker. Second is the water valve, Third is the control boards in the freezer liner where you turn the icemaker on and off. Remove the icemaker and pop off the front cover. Look at the center of the large gear. If one side of the clip that holds the gear is broken, you need a new module. You should not be able to slide the gear off the shaft. If the gear has red lettering on it, it is about 75% chance this is your problem. You should be able to get it for less than $100.
    Mike
  • Michael  Lindley
    Check that the fan motor under the fridge is running. If it is, close the doors and the center post will cool down as the fridge cools. Also pull the toe grill from the front of the fridge and clean the condenser if it is clogged with fuzz. There is a "hot gas loop" that runs in the cabinet to keep the area around the doors from sweating.
    If it is not running make sure nothing is in the blade keeping it from turning. If it spins free but won't run, you probably need a new motor. You would need to check for power to the motor to know for sure.
  • Michael  Lindley
    Also, if the fan is running and the condenser is clean, the rear cover will have to be in place so that the fan will direct the airflow properly to keep everything cool.
    Mike
I have a kenmore model # 106.54582400 that has been moved and not plugged in for 3 months , i cleaned it all up like new and plugged it in and now its not cooling , its never been on its side , the motor...
The compressor freon got leaked or compressor got damaged while shifting.Get the compressor inspected.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Kenmore Refrigerators
Wont stay cool
does it cool and then stop when it does this is there frost in the fzr compartment or ice build up. Does the fans run at all do you hear the compressor and compressor fan running. Just need more info
Aug 17, 2010 | Kenmore 57029 Side by Side Refrigerator
My Kenmore 596.50692001 side by side stopped working last night. The fan was not working at first. It eventually came back on and the unit seems not to be cooling. The compressor was a little hot???. The...
replace your fan,cause is no cooling the compressor,and check if the compressor didnt burn out to.if my info was of any help to you please leave me a comment ,thankyou.
Sep 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is not cooling properly
Look inside the fresh food section behind and inside the control panel for a defrost timer and circuit board. Let me know when and what you find. Please unplug first, Thanks, Sea Breeze
E. Cold Control & Defrost Timer/Automatic Defrost
Control
These parts can produce a snapping or clicking sound
when turning the refrigerator on and off. The timer also
produces sounds similar to an electric clock.
Mar 27, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Mar 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator and Freezer stopped cooling after intermittent noise
Hello
if the ice maker arm is down regardless of the water being off the valve will energize ( dry ) no this will not effect cooling
Apr 12, 2017 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite - 106.55606400 - Ice Maker is not working
This is the replacement for the old one they stopped making the 260w
Apr 04, 2008 | Haier HRT02WNC Compact Refrigerator
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Not cooling
it might have got stuck in defrost look for the defrost timer if it is a older fridge you can manuley turn it out of defrost to buy you time to getting a new timer
Aug 08, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
855 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
