Sony XM-2150GSX Car Audio Amplifier
Need a lil ore help!!!
posted by GhOsT1303 on Jan 05, 2008
ok i have one more thing that i cant figure out
i have got the diagram for the amp n i hooked everything up the way it
sayd to do it but i still aint hearing any sound and it keeps saying that
its eather over currceting or off set and i cant figure out y its sayin this for
cant anyone help me one more time...???
Comment posted on Jan 05, 2008
witch one is the singal wire??
ok but not all of the lights light up its only the power(green) n eather over current (red)or the offset(red) but only one comes on at a time other then the power light
is the b+ the +12volt on the battery??
so your sayin my amps blown eh damn it well thanks for the help so i gues i should jst trown this amp out eh??
how much do you think it will cost me to repair it?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
pbabin
Rank:Guru Guru
Rating: 89%, 301 votes
If the overcurrent of DC offset lights are not green, the amplifier probably has blown output transistors.
To eliminate other problems, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally (all lights green), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Signal cable = RCA cables
If any LED goes red with nothing connected excpt the B+/ground/remote, the amp is blown.
B+ = positive 12v connection to the battery
It can be repaired. Call some of the local car audio shops to see who they use for amp repairs. If you find one shop that's used by several shops, it's probably reliable.
Repair charges vary greatly so it's difficult to know what the repair will cost. Get an estimate or set a limit on the repair total when you drop the amp off for repair. If it costs more than half the price of a replacement, you should probably replace it instead of repairing it.
Page #138 of the following site has more information on getting equipment repaired.
Click here
Rating Locked! (?) GhOsT1303 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on need a lil ore help!!!:
I don't want to Accept this solution
Can you Help with these Car Amplifiers problems?
Car Amplifiers
I' ve got a 4 channel 1600 watt v-trek amp (can be...
Car Amplifiers
I have a boss rev 755 that is burnt two little things out....
Car Amplifiers
This amp was barely used, I took my time and did...
Car Amplifiers
need to find out how to connect a new cd deck to the...
Car Amplifiers
I need a schematic for an MA 744C amp from Majestic. It...
Loading problems.
Repair Service
Find Car Amplifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
