Question about Hitachi 50UX57B 50" Rear Projection Television
TV'S PICTURE WILL BINK OFF WITH TH EPOWER LIGHT STILL ON. IF I UNPLUGGE IT IT WILL RESET. IT WILL ALSO RESET SOMETIMES IF YOU TAP ON IT??? WHY??? ANY HELP?
    Novelist:
    Champion:
  • 232 Answers
ZMAN, if tapping the set makes the picture return you have broken solder connections on one of your boards, as the set warrms up the boards expand pulling on the connections, you probably only have a couple of bad ones, call a tv shop and have them solder it up for you, this is not a high dollar repair, good luck, BMW Rider
Posted on Jan 05, 2008
Why tv shuts off by itself?
Dear User,
People who have faced such problems have tried sticking th epower plug (Going into the TV) a little harder and the thing never went off again.
If this is not the case, then it could be the cat5 network cable. Try keeping it out and observe.
Let us know further
Regards,
Sid
Nov 13, 2014 | Televison & Video
Th epower will come on but no picture
Short circuited component/s at its main board. Contact any service technician. Gopakumar Gopalan Google
Mar 07, 2014 | Sanyo DP42848 LCD TV
Not getting wi Fi
  1. From the Homescreen, tap Settings.
  2. In Settings, tap Wi-Fi.
  3. Slide the slider to "on" to start your device looking for Wi-Fi networks. In a few seconds, you will see a list of all available networks (if you don't see the list, there may not be any within range).
  4. There are two kinds of networks: public and private. Private networks have a lock icon next to them. Public don't. The bars next to each network name indicate the strength of the connection - the more bars, the faster connection you'll get.
    To join a public network, just tap the network's name and you'll join it.
  5. If it's a private network, you'll need a password. Tap the network name and you'll be prompted for a password. Enter it and tap the join button in the bottom right-hand corner. If your password is correct, you'll join the network and be surfing the web. If not, you can try entering it again (assuming you know it, of course).
  6. More advanced users can click the arrow at the right of the network name to enter more specific settings, but the everyday user won't need this.
Oct 08, 2012 | Cell Phones
I have an acer AT3220 lcd tv i had problems turning it on now it just shows a red light wont turn on at all any ideas ie which capacitor or any other information would be brill as im now back to a 28inch...
Open the back of the tv check th epower supply for busted/leaking or swollen capacitors - if you have experience solder some new ones in place - use the 105degress one for a longer lasting capacitor - the radio shack ones will work but they are rated at 85 degrees and wont last as long.
thanks,
michael
Mar 31, 2011 | Acer Televison & Video
I UNPLUGGE MY TV FOR 2 DAYS AND PLUGGE IT ON BACK
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Apr 27, 2009 | Mitsubishi WS-65869 65" Rear Projection...
My tv won't stay on
check all the fuses on all the boards there are about 7 of them
Apr 18, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic prism ptm4597s
Youre going to need a service manual and some trouble shooting skills for this.type of problem. The manual is available at the following link. http://www.servicemanuals.net/
Jan 03, 2008 | Televison & Video
Hitachi 50UX57B 50" Rear Projection Television Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
