The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
One-yr old LG (DLE5955W) dryer has a high-pitched continual (constant) squeek on gentle cycle ......
(More)
One-yr old LG (DLE5955W) dryer has a high-pitched continual (constant) squeek on gentle cycle ... like something is rubbing or needs oiling. What is the problem and how can I fix it?
LG dryer vent comes lose causing fire hazard. It's a brand new LG front loader. Looking for solution...
(More)
LG dryer vent comes lose causing fire hazard. It's a brand new LG front loader. Looking for solution or other people having same problem
We have cleaned the entire dryer and had all the ductwork blown out. Even had the Sears repair guy...
(More)
We have cleaned the entire dryer and had all the ductwork blown out. Even had the Sears repair guy try to fix it...Still no resolve!!!
I have same problem too ! My dryer's lint filter light is always on and 3 airflow sensor bars...
(More)
I have same problem too ! My dryer's lint filter light is always on and 3 airflow sensor bars lighted at drying time. However, it takes an hour to dry one regular load with regular sensor dry cycle. Is that abnormal ?
dryer seems to skip cool down cylcle and shuts itself off without buzzer going off. when this...
(More)
dryer seems to skip cool down cylcle and shuts itself off without buzzer going off. when this happens, it will not start again until it cools off. the top of dryer is very hot. it does not do this all of the time, but it does it most every time i wash towels. The buzzer will sound if everything has run as it should, but does not sound if dryer shuts off and clothes are cooled down. That is what makes me think it is sometimes skipping cool down cycle. We have cleaned all vents and pipes. Husband took it apart and cleaned inside as well. Did not help. thanks
